Master cylinder question???
- Born Dead 2
16 Jun 2009 07:44
When using dual disc brakes, is there really a difference in using a 5/8" bore m/c over a 1/2" bore? Just wondering if anyone knows if a 1/2" bore will work without any issues.
Thanks in advance
BD
Thanks in advance
BD
- timebomb33
Re: Master cylinder question???
16 Jun 2009 10:55
when using a 1/2" bore master on daul disc set-up you won't get the proper feel and the the brakes can feel mushy and not have as much stopping power, the oppisite is true when you use a 5/8" bore master on a single disc it can cause overly sensitive braking and would be easier to lock up. your better off just getting the right one for the job. be safe it's not worth trying to reinvent the wheel.
I THINK MY POWERBAND BROKE
- MFolks
16 Jun 2009 10:56
My understanding is when going with duals on the front, to allways go with the larger bore. The smaller bore can and will lock up the brakes.
- jklcycles
- Avondale, AZ
17 Jun 2009 19:52
I added a second disc to my front end and kept the stock (1/2"?) master cylinder. It has worked well for 10 years now. It might be a little mussy but it works.
1975 Z1-B. Current project.
1977 KZ1000. Future project.
