wheel interchange question
- Davestradamus
15 Jun 2009 22:47
i finally have my 1977 kz650b running decent and i have really been enjoying it. she needs tires.... so i figure:
why not get a set of mags to replace my wire wheels? (till i get tired of mags and want spokes again):dry:
they seem pretty inexpensive on ebay, but i don't know what fits. i have a drum in the rear, although i wouldnt be opposed to upgrading. help!
cheers!
david
cheers!
david
- Bluemeanie
Re: wheel interchange question
16 Jun 2009 06:08
I may be wrong but I believe that a mag to wire wheel swap is a direct bolt on. If you go rear disc you will have to swap out swingarms and need to have rear resivouar bracket welded to frame. Let us know...
- JMKZHI
16 Jun 2009 07:11
Without knowing for sure, I would guess that the 1980 KZ650-E1-Ltd would be the easiest - it has the single disk front brake & rear drum. You can cross-reference the diagrams at Kawasaki.com to compare parts. I did a simple check for the rear axle & it is the same as on your bike. For the front, try to find out if the disk & caliper will line up.
Diagrams note: I find it easiest to do the Search-by-Model-Info without entering a vin or anything - just pick a year only, then choose a bike from the list. Also, it saves time if you right click & open the bike in a new window - the Kaw diagrams can be unwieldy.
- RonKZ650
16 Jun 2009 10:58
I think a 1980-83 KZ550A rear wheel would be a direct swap. Both the 650 and 550 use the same brake pads and axle, so by all odds it should bolt up like factory. The KZ550 uses a different axle in the front than a 650 so it may or may not work just by swapping the 650 axle over, otherwise a KZ650C or D front should bolt up. Advantage of the KZ550 wheel over a LTD is you stay 18". Going 16 is just wrong.
- JMKZHI
16 Jun 2009 11:34
Ron is correct: the 650-Ltd has the 16" rear wheel.
The 550-Standard models have the 18" Rr.
The KZ550 wheels are a direct bolt-on to the 81-83 KZ650-CSRs which don't have much in common with the 70s models.
- Mark Wing
16 Jun 2009 11:36
An 1980 650F1 has a 18 drum brake mag also. Going to a 16" is wrong.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
