Chain and sprocket replacement
  • fredgarvin42
  • fredgarvin42's Avatar Topic Author
12 Jun 2009 10:37
#298608
My scoot has worn out the chain and I'd like to replace it along with the f/r sprockets. I see where I can get them but I don't know what the factory gearing is (at work now so I can't count the teeth) and I'm trying to get the parts ordered while I have the opportunity.
Anyone know what the original gearing is for a 1980 LTD 1000 is? Also, where should I order from? Z1? Sprocket Specialties (expensive!) Installation dooz and don'tz?
Thanks!
Jay
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Chain and sprocket replacement
12 Jun 2009 10:59
#298610
Hello Jay...Front--15tooth
Rear --33tooth
Chain -- 630 X 92
Give Z1Enterprises a shot first...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • racer54
  • racer54's Avatar
12 Jun 2009 11:02 - 12 Jun 2009 11:02
#298611
I'd go with Z1 Enterprises. He's a great guy to deal with and goes beyond strictly business to help where he can by offering advice, etc. to whoever he can help here. His prices are just as good and generally better thne most places I have found adn we need to support that kind of support. I believe the gearing for the 1980 LTD is 15T front and 33T rear. By all means get a new chain when you get those sprockets also.
Last edit: 12 Jun 2009 11:02 by racer54.
  • fredgarvin42
12 Jun 2009 11:07
#298613
Thanks for all the scoop! Gonna place the order now.
Racer54, Yeeehaaaaw!!!!! Killer bike! Turbo AND nitrous?! My desk just rose with a slight knock.
Peace,
Jay
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
  • BSKZ650
  • BSKZ650's Avatar
12 Jun 2009 11:50
#298617
I bought mine from z1 and I went with the o ring chain, also if using the o ring chain,, buy the install tool,, sdaves fingers, and dont ask how I know
77 ltd1000, current rider
76 kz900, just waiting
  • RonKZ650
  • RonKZ650's Avatar
12 Jun 2009 12:05
#298622
Be sure and get the front sprocket with the hole in it for the lockwasher. If it doesn't have the hole, refuse to use it. I think we had some talk a while ago about Z1 ent sprockets do not have the hole, so ask before buying. Dennis Kirk sells Sunstar sprockets that are real nice with the correct hole. Running without the lockwasher will result in the nut coming off and your sprocket sliding off the splines, then you have no gears or worse. Sure you can use Loctite on the threads, but better off with the correct parts.
  • bountyhunter
  • bountyhunter's Avatar
12 Jun 2009 13:57
#298633
You can also get the kind of lock washer that doesn't need the hole: it is the kind you bend over onto the flat of the drive axle nut to keep it in place. They hold a lot tighter than the ones with the little tang that sticks into a hole.
