Rear Wheel Swap
  • KZ101
  • KZ101's Avatar Topic Author
Rear Wheel Swap
11 Jun 2009 12:20
#298385
i've read many posts about swaping out the swingarms on chain driven KZs to accomodate wider tires. Does anyone know what the widest tire i can run on a Shaft KZ1000E? Or if there is a different swingarm i can use to accomodate a wider tire and still be ok with the shaft drive?
  • KZ101
Re: Rear Wheel Swap
13 Jun 2009 20:54
#298952
i'll take it that it was just a dream to be able to get a wider tire on a shaft drive. Oh well nothing wrong with the old one, so i'll just keep on down the road. Stay safe out there.
  • edspring1
  • edspring1's Avatar
Re: Rear Wheel Swap
13 Jun 2009 21:12
#298957
Having absolutely NO expierence what so ever with shaft drives. I do know this.
If you change the output shaft in your trans over to a chain drive output shaft, of course making your bike chain drive you can put a variety of swingarms on it. Of course you have to pull the motor and split the cases to install the shaft thou.
Maybe cheaper, easier to just get a chain drive bike I am thinking.
