Rear brake problem
- supermandan713
Rear brake problem
08 Jun 2009 23:48
Im brand new to motorcycles and my 1977 kz 650 is my first bike. my rear brake will engage, but will not disengage. any suggestions?
- timebomb33
Re: Rear brake problem
09 Jun 2009 00:16 - 09 Jun 2009 00:18
the piston in the caliper is dirty and will need to be removed and cleaned and also the caliper will need to be cleaned and all the old crystalized brake fluid will have to be cleaned out of the seal grooves the a new seal kit will have to be installed and while your at it replace the brake pads as they have probably worn out enough that the pads arent returning smoothly. make sure you get a factory manual it will talk you thru the steps involved.
I THINK MY POWERBAND BROKE
Last edit: 09 Jun 2009 00:18 by timebomb33.
09 Jun 2009 03:27
Would also refurbish the master cylinder, because the pressure relief orifice might be clogged. That's the mechanism whereby line pressure is supposed to be relieved when the rider is no longer applying the brake.
Good Luck!
Good Luck!
- supermandan713
09 Jun 2009 11:44
Thanks guys, I will do all you said and hope for the best
