Drilled Rotors
- OregonMatt
Drilled Rotors
08 Jun 2009 08:44
Do slotted or drilled rotors have the same squealing problems that the solid rotors do? I have tried just about everything. The guys I ride with are starting to get pissed at the sound.
1976 kz 900
- MFolks
Re: Drilled Rotors
08 Jun 2009 10:59
Have you tried cleaning the brake pad? sometimes grit gets trapped between the pad and the brake disc. A random orbit sander lightly abrading the pad should clean it. Another thing to try is to get some "Disc Brake Quiet" from the auto parts store.
It's a spray on or tubed compound you apply to the back side of the brake pad reducing the vibration during braking.
My understanding is the brake pad makes the rotor act like a violin string when the bow is moved across it.
- OregonMatt
Re: Drilled Rotors
08 Jun 2009 12:13
I have roughed up the disc and the pads and tried the disc brake quiet and the copper silicone and everything else I can think of. As far as the violin effect, I was wondering if the drilled rotors would not squeal because they are not solid
1976 kz 900
- bountyhunter
Re: Drilled Rotors
08 Jun 2009 14:18 - 08 Jun 2009 14:20
One thing that works is to drill the pad face and install some graphite rods (like a pencil lead) and that lowers the coefficient of friction so the pad doesn't start "grabbing" until it is squeezed tighter on the disc. That worked on mine... for a while, then it came back.
I doubt if drilling the rotor would help because the noise comes from the pad vibrating against the rotor face.
Last edit: 08 Jun 2009 14:20 by bountyhunter.
- donthekawguy
Re: Drilled Rotors
08 Jun 2009 16:33
try taking the caliper off and painting the inside surfaces of where the pad fits into the caliper. Try to make it a tight fit. That might keep the pad from vibrating.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- gane
Re: Drilled Rotors
08 Jun 2009 17:06
Mat, Brake squeel is /was a common prob w.era bikes. in most cases, sound is/was caused by pads vibrating in caliper., check the area where pad locators ride.smooth if necc, If flex plates were fitted, examine. and if fitted still squeels. reverse direction. sometimes the easiest fixes are best.luck g
[img][/img] 1977 KZ1000A1
- PLUMMEN
Re: Drilled Rotors
08 Jun 2009 18:25
try some differant pads
Re: Drilled Rotors
08 Jun 2009 18:46
I agree with Plummen - different pads (Genuine Kaw if you can find them.) You may also try chamfering the leading & trailing edge of the old pads a little. This can help sometimes. Also, wipe down the rotors before you ride, this should give a little relief until they dust up again. Ed
- Mark Wing
Re: Drilled Rotors
08 Jun 2009 18:57
My old rotors squealed and I would just play a little tune with the front and rear brakes.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- Sandy
- Fly High,Tony
Re: Drilled Rotors
08 Jun 2009 19:50
Try the cheaper pads from Z1ent.
I had the same problem.The pads I was using had too much metal in them and no matter what i did,they would squeal...put in the cheaper pads and problem solved.
1977 KZ1000 A-1
- PLUMMEN
Re: Drilled Rotors
09 Jun 2009 21:18
Sandy wrote:
now it just doesnt stop! :laugh:Try the cheaper pads from Z1ent.
