Rear brake will not work
- saltydog
05 Jun 2009 17:53
I am having a problem on my rear brake on my 1981 KZ1000 CSR. I have very little pedal movement and very little stopping force on my rear brake. This was a sudden happening. If I stand and put a lot of pressure on my pedal, it will stop a little better, but not much.
I have taken my rear master cylinder apart and every thing looks and acts fine. I have taken my rear caliper apart and it looks fine.
I have fairly new brake pads. If I crack a line or the bleeder valve, it will bleed normally. When I close the lines or valve, the pedal will barely move.
What am I missing? I am about ready to give up.
Help!
Help!
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
- PLUMMEN
Re: Rear brake will not work
05 Jun 2009 18:41
is the brake pedal moving freely on its pivot?
- GPz550D1
05 Jun 2009 18:43
That is a tough one. I can only think to take the rear caliper off, leaving the brake line attached and apply the rear brake to see if the piston is moving freely.
Robert
Robert
1981 KZ550-D1
- saltydog
06 Jun 2009 01:55
Yes. With the caliper off, you can pump the piston right out of it.
06 Jun 2009 05:54 - 06 Jun 2009 06:03
saltydog wrote:
Am thinking either the pads aren't squeezing hard enough against the disc, or if squeezing hard enough, something's interferring with necessary friction between pads and disc.
With caliper off, to help determine how hard the pads are gripping the disc, could place a soft lead fishing line weight between pads and firmly apply brake to determine extent to which the weight is flattened.
Might also compare results of similar test between front pads.
If compression force between pads is adequate, perhaps the rear pads have become severly glazed or heat damaged and/or disc has oil or grease on it, either of which may impair needed friction between pads and disc.
Or just clean the disc (using acetone or brake cleaner) and install new pads, the softest organic pads available. If issue persists, then address caliper, master cylinder, brake pedal fitment and adjustment, etc.)
Good Luck!
Good Luck!
Last edit: 06 Jun 2009 06:03 by Patton.
- saltydog
06 Jun 2009 06:03
I have recently new pads. No oil, grease, or glazing on them. The problem is that I have no pedal travel to speak of. I won't be able to get back to it until tomorrow, but I plan on taking the pads out and see how the caliper moves against the disc. It's as if the pads aren't free to move. I'll check for proper installation when I reinstall the pads.
Robert
Robert
- trianglelaguna
06 Jun 2009 06:08
i know it is repeat of info but i think the pads have glazed and if sanded hard with some 80 grit or a file to remove the surface to new material and try agian -you'll notice a big improvment....still does not explain the pedal ...i'd defintitly find movement wether you got drop the pedaql and see or whatever....good luck..least you got front brakes...peace
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- anyday
06 Jun 2009 14:50
I had a similar problem last week. I noticed my brake pedal wasn't coming back up and my brake light was staying on. I ended up removing the right hand plate that holds the passenger pegs and brake mechanism and found the rod that the brake pedal is connected to was semi-seized up. I sprayed in some wd-40 and worked it loose. It was rusted in place so I cleaned the rust out and put in some anti-seize.
1981 KZ 1000-k, 1982 GS300L-D, 1982 GS300L-Z (parts)
Sioux City, IA
Sioux City, IA
- saltydog
06 Jun 2009 18:50
That was one of the first places I looked but everything was working as it should.
Thanks,
Robert
Thanks,
Robert
- gane
06 Jun 2009 19:10
Think we're all missing something here. if w/ bleeder open lever travel allows normal bleeding and piston movement, would guess master cyl and brake pedal/line ok. new pads throw a red flag. would seperate caliper and carrior from wheel w/pads & tensioner bits in place and observe pad/piston motion when operated. a wild assed guess is pads are interfearing w/ something. take a look. luck g
[img][/img] 1977 KZ1000A1
