Front Master Cylander ID / Issues
- Strizzzo
- 78 Kz1000A
05 Jun 2009 05:47
Trying to confirm/disprove whether the front master cylander setup on my bike is original or not...I suspect not. Bike is a '78KZ1000A w/ dual front disc setup. The unit seems to be a "Magura" and there are markings "16" and "00' on the plunger housing. It has a rectangular reservoir.
Front brake needs something...the handle/plunger is very slow to return to uncompressed position and I'm having no luck getting the reservoir to actually push fluid into the line in order to bleed the breaks. Lines seem clear, I'm able to push air through them, so I'm guessing I'm having some sort of issue with the spring, the diaphragm, both...or something. I'd like to order the parts to rebuild...but I don't know what/where.
Thanks for any help.
78 Kz1075A2
Portland, ME
Portland, ME
- arai59
Re: Front Master Cylander ID / Issues
05 Jun 2009 06:12 - 05 Jun 2009 06:14
K&L Supply might have what you need (rebuild kit) but they sell to dealers only. Check to see if your return fluid hole is not obstructed inside the resevoir. Magura was not OE on that bike. Magura makes a lot of replacement M/C for bikes. You might check with Jeff at Z1 Enterprises.
Last edit: 05 Jun 2009 06:14 by arai59.
- Strizzzo
- 78 Kz1000A
05 Jun 2009 08:21
Managed to track down the model info, Magura 0122020 16mm if anyone's interested. Seem to be a standard aftermarket for lat 70's Japanese dual disc setups.
Thanks.
Thanks.
78 Kz1075A2
Portland, ME
Portland, ME
