Front caliper rebuild easy ?
  • jtroop
  • jtroop's Avatar Topic Author
  • 82 650 CSR H2
02 Jun 2009 19:39
#295899
Clymer manual says take it to a dealer for rebuild. I've never done one. Is it easy ? Are they just covering themselves for safety reasons ?
82 650 CSR H2
  • JMKZHI
  • JMKZHI's Avatar
Re: Front caliper rebuild easy ?
02 Jun 2009 20:56
#295921
My bike is the 81 650-CSR & is virtually identical to yours.
The front brake is very doable. It was the first thing I refurbished - I'm not a mechanical genious but I'm no dumb-ox either. It's been a while, but I kinda recall that installing the dust seal was tricky. When reassembling everthing, your hands, the parts & work area must be spotlessly clean. Absolutely no grit.
An air compressor is handy for removing the caliper piston - be careful not to crush a finger. After disassembly, I cleaned mine thoroughly, then wet sanded it to prep it for painting. The stock paint is tough, so I only had to hit the pealing areas vigorously. After sanding, I blew it dry w compressed air. The auto parts store has brake caliper paint. After the paint cured, I baked the caliper in a low temp oven to harden it further, although it still isn't brake fluid proof.
  • donthekawguy
  • donthekawguy's Avatar
02 Jun 2009 23:21
#295938
When I rebuild them I always take a dremmel with a wire wheel to the groove that the seals sits in. There is a lot of gunk that builds up in there.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • mumbles
  • mumbles's Avatar
  • Let's do it...
03 Jun 2009 07:02
#295970
Check this post out. It was very helpful to me when I rebiult the brake caliper. I had never done it before.
kzrider.com/index.php?option=com_kunena&...d=5&id=293079#294119
2001 KZ1000 Police
1998 Vulcan 800
Houston, Tx
  • Wallybanger
  • Wallybanger's Avatar
03 Jun 2009 23:34
#296222
Very easy to rebuild. I did mine a few months ago. Get a replacement seal kit and pop your piston our with an air compressor.
