hard to move piston after caliper rebuild
  • hardr0ck68
  • hardr0ck68's Avatar Topic Author
  • Who put the what in the where?
02 Jun 2009 18:49
#295882
SO I am putting rebuild kits on my newly powder coated calipers. When I installed the piston on the new seal it did not want to slide into the bore... I had to use a c-clamp with slight force, not to hard to press it in but it certainly did not slide right in. I could not press the piston in with just my fingers.
I am wondering if there is a problem with this. The last thing I want it to have to take the rear end all apart again to fix a mistake.
What do you all think?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • timebomb33
  • timebomb33's Avatar
Re: hard to move piston after caliper rebuild
02 Jun 2009 18:52
#295885
did you use brake fluid as a lube to get the piston in place? if you did it just might have hydraliced a bit not a big problem that will happen sometimes on the other hand you may have rolled one of the seals out by accident.
I THINK MY POWERBAND BROKE
  • gane
  • gane's Avatar
02 Jun 2009 19:02
#295890
Hardrock, is piston free in bore without seal? Is seal new? is seal land clean? any evidence of powdercoat in bore? i hate to suggest it, but powdercoating is a bake on process, and heat could distort bore. luck g
[img][/img] 1977 KZ1000A1
  • hardr0ck68
02 Jun 2009 19:16
#295896
I really doubt the 450* used to powder coat would warp such a hefty piece of alum...
The boars are clean, I spent an hour washing every speck of grime out of the bores and grooves.
I did not use any fluid as a lube. I think this may be part of my problem, I am going to use DOT 5 but I only have DOT 3 on hand in the barn so I just went "dry".
1977 kz650 c1
  • donthekawguy
  • donthekawguy's Avatar
02 Jun 2009 23:23
#295940
Did you clean out the seal groove with a dremmel? I always do and use fluid as lube.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
