gas cap fix
- riverroad
- 1980 1000LTD B4
gas cap fix
02 Jun 2009 08:55
I don't know if any of you have faced this problem, but if I launch hard or bang shift, the inertia causes my gas cap to pop open and throw gasoline all over my chest and crotch. The launch would overcome the spring pressure and allow the cap to open.
Finally found an easy fix besides buying a new cap.
You can remove the two screws holding the latch cover on, and you'll see a space between the back of the latch and the cap latch housing. Put a 7/16" long piece of ball point pen spring in that space and put the housing cover back on. It will supplement the existing spring and keep it from sliding back during the launch.
I haven't had a chance to really test it yet, but I can tell already that it works. The latch snaps shut with a lot more authority.
- Buda
Re: gas cap fix
02 Jun 2009 17:47 - 02 Jun 2009 17:47
I had mine apart and lost the original spring altogether and the pen spring worked to replace it.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 02 Jun 2009 17:47 by Buda.
- riverroad
- 1980 1000LTD B4
Re: gas cap fix
03 Jun 2009 06:51
Yeah Tom, I thought about just replacing the spring with a pen spring, but it looked like the original spring was smaller in diameter and I didn't think a pen spring would fit in the groove.
Anyway, tested it last night. Works great.
Now I need more horsepower.
