Rims Rims Rims!
- JorgeRox
Rims Rims Rims!
09 Mar 2006 06:09
Can someone tell me if a 1980 kz750E rim will bolt onto my 77 kz750 twin? It's driving me crazy, I've searched and searched, no luck. I would surely appreciate any help......................:woohoo:
- steell
Re: Rims Rims Rims!
09 Mar 2006 08:06
It's not a bolt in
The axle on the 750E is smaller than the axle for the 750 twin.
- JorgeRox
Re: Rims Rims Rims!
09 Mar 2006 11:11
I'd have to buy the right size axle? So i can't just switch my hub with the 80 model?
- craigpuckett
Re: Rims Rims Rims!
09 Mar 2006 12:56
find a kz1000 rim they have the same axle size and should just bolt in.
just be sure to get the same brake (disk vs drum)
just a thoughtB)
just a thoughtB)
- steell
Re: Rims Rims Rims!
09 Mar 2006 14:22
Yep, the KZ1000 rear wheel will bolt on.
To use the KZ750E wheel you would have to use the axle/spacers/caliper and hanger/cush hub, and then you are going to have a 17mm axle in a 20mm hole, and that means the rear axle can move around.
If you are wanting to convert from wire wheels to mags, then use the 1000 rear mag and the 650 or 1000 front wheel. That's the easiest solution.
- JorgeRox
Re: Rims Rims Rims!
09 Mar 2006 16:34
Cool; I'm in the 3rd year of restoring this, I've added too many parts to list, in this thread, anyway. Last year, my brother in law forgot to tighten my front fender bolts all the way, I went for a "short test ride." The fender slipped, and locked up the front wheel, over the ole handlebars I went. The"short test ride" wound up taking about 5 months to heal my right arm, broken in 7 places. A stupid, stupid mistake on my part, for not double and triple checking everything before the ride. Everybody reading this, don't repeat the stupid thing I did, check everything thoroghly. I'll be posting pics of the Twin, soon.
I just got the seat back today from the upholsterer. I'll find a 1000 for the mag, thanx again...............................J.R. [img size=150]
