Steering race removal (again)
  • jtroop
  • jtroop's Avatar Topic Author
  • 82 650 CSR H2
31 May 2009 14:00
#295317
I've read several previous posts on this topic but haven't found my particular question addressed. Contrary to the drawing in the Clymer manual - both the upper and lower outer races have an inside diameter essentially equal to the steering head I.D. In other words, there's no edge or anything to "get hold of" to beat it out with a drift. Any thoughts ?
82 650 CSR H2
  • DoubleDub
  • DoubleDub's Avatar
Re: Steering race removal (again)
31 May 2009 16:30
#295354
Can't speak to the 650, but the loose bearing race on my Kz900 did have an edge that I could get a punch/chisel/screw driver on and pound it out. However, the new tapered bearings I just put in did not and will be much harder to remove if they ever need to be replaced.
31 May 2009 17:20
#295364
On my KZ650 there wasn't much edge, but there was just enough to catch with a 1/2" rod. You may need to angle the rod down through the neck rather than try to keep it parallel to the neck. Ed
  • jtroop
  • 82 650 CSR H2
31 May 2009 19:39
#295399
There were already tapered bearings in there which is apparently what is causing my problem (no edge). The top outer race is rusted/pitted so not even close to reusable. Is it time for a dremel cutting wheel ? Something else ? Thanks, guys.
82 650 CSR H2
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
31 May 2009 19:58 - 31 May 2009 20:03
#295407
I bet this will grip it. It's a front lower race remover for a Valkyrie.
We Hit on this about three months ago.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 31 May 2009 20:03 by KZQ.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
01 Jun 2009 13:45
#295508
"if"you have a welder run a bead around the inside of the race(bearing surface)this will shrink it.then weld something across it from side to side and then you can hit the piece you weld in and it will come right out.while you have it out take a dremel or such and cut a couple notches in the neck cup across from each other so next time you can knock it out with a pin punch through the notches.
hth,
leon holmes
  • gane
  • gane's Avatar
01 Jun 2009 14:18
#295516
J, Have run into your prob a couple times, my solution while not as neat as welding is to whizzer wheel thru bearing shell at a low angle. bearing races are brittle and often break/relax before fully thru. this slot gives something to drive against, and even if you do go thru, damage to seating area is minimal. luck g
[img][/img] 1977 KZ1000A1
