01-03 GSXR fork swap?
- Yojymbo!
30 May 2009 15:06
Other than not being USD forks is the 600 of the same year as the GSXR 750 the same swap? They are way cheaper and I'm on a budget. Also, do the brakes have to be changed if keeping the stock wire wheel?
Thanks
Thanks
- StreetfighterKz
Re: 01-03 GSXR fork swap?
30 May 2009 15:11
The 600/750/1000 frontends all interchange with no mods. You'll have to do something with the brakes as the Gsxr disks are further apart and a different diameter and thickness compared to the stock Kz brake setup.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Z1109R Fin
02 Jun 2009 02:06
GSXR has 17" front wheel. That´s probably smaller diam. as your stock is so brake disk may not be the same diameter either. Also new rims are wider that KZ originals. So all in all keeping the old wire wheel may not be as simple as it looks.
Z1000R ´83...Slightly modified...
- Yojymbo!
22 Jun 2009 04:55
Thanks guys, I just picked up a set of 01-03 GSXR forks for $50. Going to use the stock ones I just rebuilt until I can work out what to do with them.
