Bottom Steering Race Kz900
- DoubleDub
30 May 2009 14:27
So I have my new tapered bearing races to install, but I'm struggling to remove the bottom race/seal. I've tried my biggest hammer so far and the thing just won't budge.
I know this has probably been covered before, but the search button wasn't helping me find the answers. Any tricks as to loosening up the 33 year old race from the neck?
- donthekawguy
Re: Bottom Steering Race Kz900
30 May 2009 14:43
I always cut them off with a dremmel.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- DoubleDub
30 May 2009 15:43
Thanks Don! I cut two groves in them using my Dremel and a cut-off wheel and a little tap tap and some grease on the steering neck and they popped right off!
Thanks for the help!
- PLUMMEN
30 May 2009 16:34
tossing triple tree in freezer for 1/2 hour or so before installing new bearings couldnt hurt
- DoubleDub
30 May 2009 16:40
Thanks. I think I'm going to have to do that as I don't have any type of press that will get the lower bearing on - I didn't realize how tight it fits on the steering neck.
- oldkaws4ever
- Have no regrets...... You only live once.
30 May 2009 17:39
donthekawguy wrote:
Yup, that is what i did with my z1 to get the races out, it worked perfectly.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- PLUMMEN
30 May 2009 19:40
see if you can find a piece of pipe that fits around steering stem to help drive bearing on
- DoubleDub
31 May 2009 06:00
I had seen that recommended, also using the old race on top of the new bearing so you weren't banging directly on the new bearing set. I haven't found the pipe I need, though.
- DoubleDub
31 May 2009 16:32
Well, some improvisation saved the day. I couldn't find a pipe with the right I.D., but my buddy suggested using the very large and cheap adjustable wrench that I had an slowly bang with hammer and rotate around the steering neck. This worked beautifully.
Thanks again!
Thanks again!
