240 rear tire
- ernie
240 rear tire
29 May 2009 00:13
I have been seeing a few KZs around with 240 rear tires and I,m needing information as much as I can get on how to get this accomplished. I have an aftermarket swingarm +6" that I got from redlinecycles I have converted to a 530 o-ring chain. Hurry Hurry man riding season is already here.
- StreetfighterKz
Re: 240 rear tire
29 May 2009 04:27 - 29 May 2009 04:28
To run a 240 rear tire you'll need an outboard bearing support. To get the wheel centered in the frame, you'll have to A)run a jackshaft (see attached pic(personally I think that will look tacky)),
replace part of the frame with rectangle tubing so the chain runs through the frame for proper alignment, C) or run the chain on the outside of the frame.
Is the swingarm even wide enough to fit a 240 tire with the cush drive, caliper bracket, etc? I thought the Redline arms were good up to about 200mm tires?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 29 May 2009 04:28 by StreetfighterKz.
- Old Man Rock
Re: 240 rear tire
29 May 2009 05:09
Streetfighter hit it right on the nose...
"Hurry Hurry man riding season is already here."
Seriously this isn't a weekend project...
You have chain to frame issues, frame support fabrications, rear suspension ( duals or mono) fabrication mounting issues, if mono then all your electrical/battery box requires modifications, chain and sprocket issues to contend with and now through into the mix, front end requirements to make this a somewhat decent & safe ride...
Unless of course you only plan on riding in a straight line all the time. :blink:
Again seriously speaking, slow down and do your research for can it be done, yes anything can be accomplished but at what price/time... Definitely not this weekend... :ohmy:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
- ernie
Re: 240 rear tire
29 May 2009 19:19
Thanks guys thats what I was wondering I will abandon that idea.Seems like alot of trouble for just a little resultand besides I want the bike to look as stock as possible and not butcher it all up.
- kzr750r1
Re: 240 rear tire
29 May 2009 19:34
Other than looks why anyone whould you want a beach ball for a rear is beyond me. Leave that to the chopper set and see if they can keep up with you in the twisties.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- kzmarvo
Re: 240 rear tire
29 May 2009 20:11
I like the look of the fat tire bike,on OTHER POEOPLES BIKES...:laugh: 200mm is as wide of a ntire as one would want for twisties,i had a ninja and the 200mm tire actually wasnt as good as the 180,190 tire. One wouldnt think that lil diff would make a diff but it did.. Got a 190 on my ol kz,fat enough for the girls i go with....:huh:
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
