Need help with changing a rear tire...
- eriefeeling
28 May 2009 19:48
Hello all, I am in need of some advise or suggestions. I am trying to change the original rear tire on my '81 KZ 650. My problem is that the bead is basically cemented to the rim. I cut the tire off and just have the beads attached to the rim. Does anyone have any ideas for getting these beads off the rim?
Re: Need help with changing a rear tire...
28 May 2009 19:58
I would apply a solution of dish detergent and water to the bead/rim area and keep it wet for a couple days to see if it loosens.
- grumpy56
28 May 2009 19:59
A torch might work!
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- eriefeeling
28 May 2009 20:00
That's not a bad idea...Thanks I'll give it try.
- bountyhunter
28 May 2009 21:53 - 28 May 2009 21:54
I'll bet brake fluid will dissolve it. You could also spritz it with brake cleaner spray (acetone) along the stuck edge.
Last edit: 28 May 2009 21:54 by bountyhunter.
- mtkawboy
29 May 2009 12:32
If you have a hi-lift jack I put the wheel & tire on some 4x4s and jack it from the bumper of my truck to the bead. Ive since bought a Harbor Freight tire machine with a bead breaker. On a Bonneville bike Ive had to actually saw the tire off the rim and then ground the bead away with a Dremel tool. Its a bigger pain if you have the bead locks on the wheel.
