gs1100 swingarm,tire and chain conversion
- toad
27 May 2009 15:16
ok I know this has been gone over alot but I still need a little help. I have a kz900 and am putting a gs1100e swingarm on.I plan on using a 4.5"rim 170 (katana tire)and would like to know if I will need a 530 chain and or sprockets if so could someone recommend how many teeth on these 530 sprockets and what chain do I buy (they must be different lenghts)correct also would anyone know of other rims that would be in the ball park for a 160/170 tire as the 4.5" rims are kind of hard to find. thanks for all the help,this is an awesome learning expierience.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- Royal1MC
- Is it just me, or is it just great to be on a KZ
Re: gs1100 swingarm,tire and chain conversion
27 May 2009 16:52
I currently have a zx6 rear wheel 5.00 wide on the 170 tire.
Also using the 530 chain 17 counter and 38 rear sprocket. As far the length, I got a good deal on 130 link 530 chain from Chaparral, forgot how many links I removed. Almost forgot my swingarm is 6 over, which if I'm correct would give about 2 over. Good Luck
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Los Angeles, CA
- Mercymac
28 May 2009 18:34
I also have the 1100 swingarm and the Zx6r rim only with a 180... so i need a 530 sprockets.. 5/8 offset front sprocket.. and a 130 link chain??? lol..
"If you dont know where you're going, its hard to get there.."
- toad
28 May 2009 18:41
ok but is there a preferred sprocket or can I just use the stock ones off my old tires
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
