Changing front sprocket
  • Techhead0_3
  • Techhead0_3's Avatar Topic Author
26 May 2009 16:44
#294202
I have a 1980 KZ750G twin, 5 speed and I am looking to get more speed out of fewer RPM's. It has a stock 16 tooth front sprocket on it now and wasn't sure about going smaller or larger with it. Is there a better ratio to go with if I change both the front and rear sprocket or am I better off just changing the front? For me to do 60 mph on the highway it runs about 4,900 rpms.
1980 KZ750G1 LTD
  • DoubleDub
  • DoubleDub's Avatar
Re: Changing front sprocket
26 May 2009 18:39
#294243
I'm no pro, but typically I've seen guys change the rear sprocket before changing the front. A smaller rear will give you a "longer" gear ratio which means more speed with fewer rpms but slower acceleration. Opposite with a larger rear sprocket.
  • MFolks
  • MFolks's Avatar
26 May 2009 18:51
#294245
Here's a website you can use to figure ratio's with new sprockets, and tire size: www.gearingcommander.com
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
26 May 2009 20:09
#294268
I chose the other route when replacing both sprokets and chain. 17T front (16T standard) and 38T standard rear fit with a standard 106 link chain. 17T fit without removing the sheet metal chain guard. This dropped about 500 RPM at 60 MPH.
While changing sprockets, I had a tough time getting the side cover off around the side stand spring stud. I fixed that with a file while I was at it.
Makes removal for changing oil easier also.
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
  • brianrae33
  • brianrae33's Avatar
26 May 2009 20:20
#294271
i've always thought changing one tooth on the counter sprocket {front} equates to about three on the rear..
1982 kz1000ltd
  • bountyhunter
  • bountyhunter's Avatar
26 May 2009 22:21
#294302
That is accurate for a stock 750 twin which starts out geared 16/48. Going up to 17 on the front is the same as dropping to 45 on the back.
  • bountyhunter
26 May 2009 22:24 - 26 May 2009 22:30
#294304
Wierd, my 750 twin with stock gears spins 5000 @ 70 mph (about 4300 @ 60 mph). Make sure you have the stock 38T on the rear, sounds like you don't.
You can put a 17T on the front and drop the RPMs about 6%.
You will need to buy a big socket to fit the front drive shaft nut. Keep the rear wheel on and hold the rear brake when you crank on that nut. It will also have some kind of locking washer on it you need to clear before the nut can turn.
FYI: I am running 17 / 38 on my 750 twin right now with a 110-90 rear tire, and I wish the gearing was higher. I think optimum for me would be about 17/36, or even 17/35 with that size tire FOR SMOOTH CRUISING ON THE EXPRESSWAY. Just my opinion. Of course, you do give up some acceleration for this.
However, if the rider is heavier than me by a lot (I weigh 170) the bike might lug too much geared 17/35.
YMMV
Last edit: 26 May 2009 22:30 by bountyhunter.
  • timebomb33
  • timebomb33's Avatar
27 May 2009 07:06
#294344
if your changing your gearing it is always easier and cheap to change the front sprockets and 1 tooth on the front is around the same as going down 3 teeth on the rear.
I THINK MY POWERBAND BROKE
