fabricated offset counter shaft sprocket.
21 May 2009 20:03
i finally got some pics of one of the offset countershaft sprockets that i have built.it is a 3/8's offset 520 17 tooth.i torch the teeth off and the splines out (accordingly)then machine the inside and outside (accordingly)then build a spacer to match everything and weld it together.here is the pic.
leon holmes
leon holmes
- kano
- Not Another Bloody Limey!
Re: fabricated offset counter shaft sprocket.
21 May 2009 20:06 - 21 May 2009 20:08
Last edit: 21 May 2009 20:08 by kano.
21 May 2009 20:06
- kano
21 May 2009 20:12looks like it takes a bicycle chain,hehe.
spins the sh!t out of a 200/190 whatev,luvit.
thanks kano,i'm gonna keep practicin.i'll be real good one day.:laugh:
21 May 2009 20:16
- Old Man Rock
22 May 2009 05:02
Nice TIG job there....
I have to say, I'm impressed especially considering some of the cc sprockets offered on the web don;t look as good as that... Good job indeed...
What bike is this going on?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
22 May 2009 08:12
thanks for the compliment omr.
that one just came off of my z1r that i built the swingarm for and put the r1 wheel tire and brake on.i built an 18 tooth that is on there now.i live 2 1/2 miles off from i-75 which has a 70 mph speed limit and if you can't cruise at 80 mph you will get run over.so i was wanting to lower my cruising rpm's a couple thousand,the 18 seems to do the trick.
current gearing is 18/38 with a 190/50-17 tire and 520 o-ring chain.i can still pass without downshifting(handfull of throttle)and it seems like it will go on forever.i have buddies with v-max's and v-65's and i like to be able to walk off from them on the highway,hehe.
keeps em more "respectful" haha.
leon holmes
leon holmes
