How to install dust seal on brake caliper
- mumbles
- Let's do it...
21 May 2009 10:41
Hey folks the rear brake caliper on the KZ750 was getting stuck on me so I ordered a brake calper rebuild kit. I took it apart and cleaned it. The inside seal was a breeze to install but the dust seal is proven to be a pain in the --- to install. I used plenty of fluid to lube it and still cant get the sob to slide in.:blush:
How does the darn thing go? LOL
Any help is apprieciated.
2001 KZ1000 Police
1998 Vulcan 800
Houston, Tx
1998 Vulcan 800
Houston, Tx
- MFolks
Re: How to install dust seal on brake caliper
21 May 2009 10:50
Try soaking it in very hot water to make it more flexible.
The same goes for carb boots.
- OnkelB
21 May 2009 11:09
You're talking about the dust seal that goes around the brake piston and has to fit around a collar, right?
If so I just had the same problem rebuilding the front calipers on my 650 - I found that the easiest way is to pry out the collar with a broad flat-tipped screwdriver, mount the seal on the collar then press the assembled collar and seal back in.
Be careful when prying out the collar, you don't want to deform it, just go easy and work around it and it should come right out.
77 KZ 650 B1, 82 GPz 1100 B2.
- mumbles
- Let's do it...
21 May 2009 11:23
Yes the rear brake caliper. I got the old one off but having difficulties installing the new one.
So install the dust seal on the piston first and then install the piston on the caliper? I tried it but cannot get the dust seal to seat in the inside of the caliper groove.
I'll give it a try after runnng it trough hot water.
2001 KZ1000 Police
1998 Vulcan 800
Houston, Tx
1998 Vulcan 800
Houston, Tx
- dman3998
21 May 2009 11:51
my trick with rubber parts is starting fluid. spray some on and the boot or what ever is slick as snot for about 30 seconds then when it evaps it is dry as before with no residue. works super slick on hand grips, I dont even use glue, just spray on and they slide right up then grip super when the fluid is gone. works in reverse too, slide a philips screw driver in from the end and squirt some juice in, pull the driver and twist pops right off.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- OnkelB
21 May 2009 12:57 - 21 May 2009 13:13
No, I mean pry out the collar that makes the groove - the pics show one of my spare 650 front calipers, but yours should be similar in construction:
Last edit: 21 May 2009 13:13 by OnkelB.
- OnkelB
21 May 2009 12:57 - 21 May 2009 12:58
Last edit: 21 May 2009 12:58 by OnkelB.
- OnkelB
21 May 2009 12:58 - 21 May 2009 12:59
Last edit: 21 May 2009 12:59 by OnkelB.
- OnkelB
21 May 2009 13:00 - 21 May 2009 13:12
Last edit: 21 May 2009 13:12 by OnkelB.
- OnkelB
21 May 2009 13:01 - 21 May 2009 13:01
Last edit: 21 May 2009 13:01 by OnkelB.
- OnkelB
21 May 2009 13:02 - 21 May 2009 13:02
Last edit: 21 May 2009 13:02 by OnkelB.
- hardr0ck68
- Who put the what in the where?
21 May 2009 17:12
OnkelB that was an awesome response. I just wanted to say great job man!
+2 Karma points for Onkel
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
