rear caliper question?????
  • keith1
  • keith1's Avatar Topic Author
19 May 2009 17:49 - 19 May 2009 17:50
#292746
i m taking bike in for a state inspection tommorow and i was looking it over and i noticed that when i engage rear lever,caliper moves outboard about a millimeter or two....is this normal and something i never noticed before?
i have developed a squeal at times also...are the two symptoms indicative of a stuck piston?....just wondering...thanks......keith
Last edit: 19 May 2009 17:50 by keith1. Reason: crappy typer
  • MFolks
  • MFolks's Avatar
Re: rear caliper question?????
19 May 2009 17:56
#292750
It's normal for calipers to move as the brake disc wears.
The squeal may be caused by buildup of brake dust/disc material. Sometimes the pads can be lightly sanded to reduce squeal. Auto parts stores sell a disc brake quiet you apply to the back side of the brake pads to deaden the vibration during braking.I'd check the rear caliper for operation and clean the system.
  • keith1
19 May 2009 18:00
#292752
thanks....pads have about 500 miles on them and i didnt put any anti squeal on the back....not a biggee....just wondering about the movement.....
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
19 May 2009 18:19
#292761
The calipers do move, as they are floating on the mounting bolts.
The piston and pads position limit the amount of movement.
When rebuilding and cleaning the calipers, then reinstalling them with the piston and pad moved almost all the way in, the caliper has tons of movement until you pump up the system and the piston and pad move out.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • gane
  • gane's Avatar
19 May 2009 18:50
#292770
Keith, my front calipers have single pistons, and the calipers do indead float to compensate for inner pad wear, tho discernable motion is minute. my rear caliper (kz1000 A1) however is solid mount to it's carrior and has pistons on both inside and out, which receive same pressure from master. I believe any motion there would be from a frozen piston, or a pad incorrectly located. causing the carrior to deflect. (if your's is same) have a look and see If you agree. Luck G
[img][/img] 1977 KZ1000A1
  • keith1
20 May 2009 17:49
#292965
i m thinking due to the fact the rears are double piston and solid mount, i should nt see any discernable movement....i understand movement with a single piston.....i ll keep an eye on it and probably get a rebuild kit for back caliper.....thanks everyone.....
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
20 May 2009 19:28
#292994
I didn't relize the '78 kz1000's came with two piston calipers. I thought they were the same single piston calipers as either the '78 or '79 KZ650s.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • keith1
20 May 2009 20:01
#293001
not a biggee....all part of the learning curve....thanks for the input......B)
  • keith1
24 May 2009 18:02
#293755
upon further investigation they are single piston...
should i hear light dragging when wheeling the bike around?..can these be fixed?...can the piston be cleaned up for smoother action?....thanks...keith...
