Hardtail
- Mercymac
Hardtail
14 May 2009 19:14
WIthout doing any welding, what can i use to make my bike into a hardtail?? i have the KZ900 with a GS1100 swingrm.. (picture)
"If you dont know where you're going, its hard to get there.."
- Mercymac
Re: Hardtail
14 May 2009 19:24
Ok, now where do i get these struts.. haha
Re: Hardtail
14 May 2009 19:24
No eBay APP ID and/or Cert ID defined in Kunena configurationFor example, ebay item 230339287604
Re: Hardtail
14 May 2009 19:38 - 14 May 2009 19:42
Usually the swingarm end is further rearward than the top bolt so that the mounting angle is similar to a standard dual shock angle.
Am thinking this angle wouldn't work very well, if at all, with shocks. But am uncertain about struts.
Could probably weld tabs onto the swingarm to relocate lower mounts.
Others should have better advice about the mounting angle involved, with struts or shocks.
Good Luck!
Good Luck!
Last edit: 14 May 2009 19:42 by Patton.
- tachrev
- Rubber Side Goes Down
Re: Hardtail
14 May 2009 19:43
Patton wrote:
Isn't the shock mount where the box end of the wrench is hanging? I think the mount you are looking at may be for the turn signals.
I made the same mistake until I really looked at the picture, unless I am still totally confused.
Others should have better advice about the mounting angle involved.
Good Luck!
Build Thread
Build Thread
Re: Hardtail
14 May 2009 20:00
Am thinking lower shock or strut mounting position further back on the swingarm, such as this one.
[Click for better view]
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: Hardtail
15 May 2009 05:09
If I'm not mistaken I think the lower shock mount on this swingarm is the forwardmost hole with what looks to be a bushing in it. I believe Suzukis use a different type of rear shock than a Kawi does.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- tw..
Re: Hardtail
15 May 2009 05:49
I got my struts from pingle.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
1978 Z1R
Re: Hardtail
15 May 2009 06:26
The Gringo wrote:
I concur with The Gringo, and believe this pic illustrates the designed lower bushing mount.
Good Luck!
Good Luck!
Re: Hardtail
15 May 2009 06:36 - 15 May 2009 06:39Would not be surprised to later hear of yet another strut fitment being quickly abandoned in favor of shocks. :laugh:
And btw, very handsome bike!
Last edit: 15 May 2009 06:39 by Patton.
- StreetfighterKz
Re: Hardtail
15 May 2009 06:37
Why do you want to make your bike into a hardtail? You'll get better traction with correctly setup shocks.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
