Fork Cap Seized in place 1981 KZ550 D1(GPZ)
  • entrancer1224
  • entrancer1224's Avatar Topic Author
11 May 2009 06:46
#290163
1981 KZ550 D1(GPZ) 36mm Air pressurized forks. One of my fork caps seems to be seized to the fork wall. I've removed the spring clip and given them a good wallup with a hammer and socket for a couple minutes. I have also soaked the cap with Penetrating spray. Has anyone else ever encountered this. Here is a link to another GPZ550 post with a pic of how it looks.
kzrider.com/index.php?option=com_kunena&...d=5&id=277194#277733
Any thoughts.
  • timebomb33
  • timebomb33's Avatar
Re: Fork Cap Seized in place 1981 KZ550 D1(GPZ)
11 May 2009 07:25
#290169
your doing the right things sometimes that top rubber cap leaks a bit and they the caps will corrode in place so just keep working at it.
I THINK MY POWERBAND BROKE
  • JMKZHI
  • JMKZHI's Avatar
11 May 2009 11:15
#290206
My bike has the screw-in type of fork caps. They were frozen: after applying some heat w a propane torch, they came right out.
  • entrancer1224
11 May 2009 20:46
#290421
Thanks guy. The second night of PB did the trick. After a couple more minutes of pounding the cap freed itself and shot half way across my buddies yard.
  • timebomb33
11 May 2009 22:11
#290430
oh yah i guess i should have warned you about that slight possibility. sorry no body lost an eye i hope.
