Whats the neck ID of the kz1000 + 440?
- djnubz
19 Oct 2005 20:49
I need to know the ID of the 77 kz 1000 neck and the ID of the kz440 neck. Can someone help me with this?
- djnubz
- twowheeledterror
Re: Whats the neck ID of the kz1000 + 440?
23 Oct 2005 23:20
What exactly are you attempting to do here?
I would assume put the KZ1K on the 400?
- dgfischer
24 Oct 2005 05:40
The 77 KZ 1000 uses 30 X 48 X 14 (ID X OD X height- of the the bearing- in mm) top bearing / 30 X 52 X 17 lower bearing.
The KZ 440 uses 30 X 48 X 14 top bearing / 30 X 48 X 13 lower bearing.
These measurment are from a tapered steering bearing kits.
You would probably need the KZ 440 bearing kit to put a KZ 1000 front end on the 440
Daniel
Daniel
