Need Reflector
  • poolboy
  • poolboy's Avatar Topic Author
Need Reflector
05 May 2009 19:46 - 05 May 2009 19:47
#288258
Where can I find a reflector for a 1980 Kawasaki 750-4 LTD.
The one I need is the one mounted just behind the forks on the frame.Thanks [/img]:)
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
Last edit: 05 May 2009 19:47 by poolboy.
  • Iron Duke
  • Iron Duke's Avatar
  • what are you rebelling against?
Re: Need Reflector
05 May 2009 23:20
#288359
Saw some on E-bay a few times in differant spots beleive thay are all same ? on 440-550-650-and 750s no thay were under a Hamilton in price
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
  • JMKZHI
  • JMKZHI's Avatar
Re: Need Reflector
06 May 2009 06:26
#288431
I was going to suggest using the cross-reference at Kawasaki.com, but there don't seem to be any part numbers. I would guess those were used on the following bikes: 80-83 KZ750-Ltd-4, 81-83 KZ650-CSR; & probably others.
Babbitt's online has the part numbers - the label housing & reflector are listed separately in the Frame Fitting diagram for some of the other models mentioned above. There is a pair of label housings (without reflectors) listed together on ebbaayy.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Need Reflector
06 May 2009 06:57
#288446
Hey poolboy...the part number is 28001-1015 and the reflectors were used on 1980/81 KZ550-C1/2, KZ650-H1, and KZ750-H1/2...eBay is your best bet.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • poolboy
Re: Need Reflector
06 May 2009 17:49
#288579
Thanks Guys, did'nt know about babbitts on line. Got it earmarked, and thanks for the parts numbers, that will all help in my search. :) :)
  • JMKZHI
  • JMKZHI's Avatar
Re: Need Reflector
06 May 2009 20:07
#288642
FYI: Babbitt's won't have 'em, so don't waste your time ordering anything. I just use their diagrams etc as a reference.
  • l0g1c
  • l0g1c's Avatar
  • Hanging on for dear life.
Re: Need Reflector
06 May 2009 21:13
#288663
I've got one I took off of my '81 LTD, since the other was missing. Shipping + whatever you think it's worth and it's yours.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
