Supporting and lifting bike with headers
- chefrob78
23 Apr 2009 17:36
Hi,
I have a 78 kz650b with aftermarket headers/exhaust. The center stand has been removed and the exhaust runs under the motor/chassis. How can I support the bike to take the wheels off and/or change the oil and filter? Do I have to remove the exhaust? If I do remove the exhaust can I reuse the manifold gaskets? Im new to this site and this is my first KZ. Thanks for any help!
- saxjonz
- KawboyZ
Re: Supporting and lifting bike with headers
23 Apr 2009 17:45
Let me just ask a few questions. Can you see the tangs underneath the bike where the center stand fits? Are they blocked from being able to put one on? LTDs don't have center stands but still have the place for them. And second do you still have the center stand? It isn't too hard or expensive to find one. I have a header on my bike too and I can still put a center stand on the bike although I don't keep it on but I use it to lift the bike with the center stand changing the oil. If you have to remove the header. I had to with my zr1100 to change the oil you can just remove the latter part thus not worrying about the gaskets. I would assume that if the header is any good you should be able to do this. I am sure you should have no problems with this. But.....
79 LTD B3
- bountyhunter
23 Apr 2009 17:48
It might be easier/cheaper to spend maybe $60 on one of those floor lift devices that lift the frame from underneat. I see them for sale all the time.
- PLUMMEN
23 Apr 2009 17:48
- chefrob78
23 Apr 2009 17:58
Thanks saxjonz, I do have the tangs still. I'm going to try to find a center stand. As for removing the header, it looks like the muffler can be removed? Does that sound right?
23 Apr 2009 18:00
chefrob78 wrote:
Hello, chefrob, and WELCOME to KZR!
We're glad you're here!
If can access the oil drain plug without removing exhaust, just prop bike upright while it drains.
Some exhaust systems must be removed to access the oil filter (bummer).
Whenever removing the exhaust system, I prefer replacing the copper o-ring gaskets with new ones, and not re-using the old ones or attempting to rehabilitate them by torching.
Many folks fit a temporary centerstand for maintenance chores, wheel removals, etc.
There are special stands to suspend the rear end for wheel removal.
Jack stands may also be used to suspend the rear end.
Also, a standard floor jack may be used while the bike is on the sidestand under the bike's rear right side to raise the bike's rear wheel off the floor. Whereby the bike is leaning supported at three points (jack, sidestand, and front wheel) allowing removal of the rear wheel.
Of course, during any of these maneuvers, be very careful to position things so everthing remains ultra-stable and nothing apt to slip out of place.
Good Luck!
Hi,
Good Luck!
- saxjonz
- KawboyZ
23 Apr 2009 18:08
bountyhunter wrote:
The wheel chock thing that the racebikers use might be easier and about the same price to find. I have never used one before. I always use a center stand OEM. Try and see if you can take off the stuff without the necessity of removing the can if you can...:huh: anyway I think you will figure it out. I like using the center stand to change my oil that way I can let her drip dry before I put the clean stuff in it. Maybe that is a bit far but I figure the cleaner the better.
Yes but...on my 79 I used one of those to take the wheels off and I had to remove my header completely.It might be easier/cheaper to spend maybe $60 on one of those floor lift devices that lift the frame from underneat. I see them for sale all the time.
79 LTD B3
- Vter Bob
23 Apr 2009 18:31
Seems to me I remember reading a thread about someone removing the gas tank and suspending the front of the bike with a strap around the backbone and a garage rafter. Maybe I dreamed it...:blink:
Oh, and both of my LTD's have centerstands...
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
1981 KZ550 LTD
1982 KZ1000 LTD
- kano
- Not Another Bloody Limey!
23 Apr 2009 19:01 - 23 Apr 2009 19:02
PLUMMEN wrote:
lol.
got one of these (little girl not included)
got these for Christmas (not the bike)
lol.
Last edit: 23 Apr 2009 19:02 by kano.
- saxjonz
- KawboyZ
28 Apr 2009 18:42
Vter Bob wrote:
I had the center stand from my 76 and kept it but I don't think it fit well with the stock pipes or something. At any rate I just use it to prop the bike up when it's stored and to change the oil. It's a heavy piece to be on the bike IMO.
So the question is did these bikes come stock with them or without. Plummen dude?
What year is yours? I have a 79 that I bought with 5k miles when it was 7 years old and I asked what happened to the center stand and the guy said that he bought it new like that and the bike I bought from cali didn't have one either and it is an 80. I just figured they didn't come with them stock because they were the ltd models.Seems to me I remember reading a thread about someone removing the gas tank and suspending the front of the bike with a strap around the backbone and a garage rafter. Maybe I dreamed it...:blink:
79 LTD B3
- 88alltrac
28 Apr 2009 21:19
my 81 has a center stand.
81 KZ1000 K1
Lincoln NE
Lincoln NE
- Vter Bob
29 Apr 2009 16:31
My 550 LTD is an 81 and my 1000 LTD is an 82.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1981 KZ550 LTD
1982 KZ1000 LTD
