Changed the tires now I have a squeak HELP!!
  • Jason1976
  • Jason1976's Avatar Topic Author
22 Apr 2009 21:31
#284249
I have an 82 KZ750 Spectre that is shaft driven. The good news is that I got new tires. My friend and I installed them. The bad news is that now when I have it on the center stand with the rear tire in the air I have a sort of strange rubber grinding sound. It isn't like metal grinding it sounds like rubber. There is nothing touching the tire. When I ride the bike it turns in to a pretty loud squeaking sound. We didn't remove the wheen bearings so we didn't pack them. Any ideas on what this could be?
  • gane
  • gane's Avatar
Re: Changed the tires now I have a squeak HELP!!
24 Apr 2009 18:07
#284910
Jason, many shaft drive bikes have a plastic sheild which seals final drive to rear hub. thats where I'd start the search. luck G
[img][/img] 1977 KZ1000A1
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
25 Apr 2009 17:11
#285232
Did you end up with an extra part? Possibly the drive spacer? It's a tube about three inches long an 1 1/8 in diameter?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
