replace master cylinder
  • clutch2k3
  • clutch2k3's Avatar Topic Author
21 Apr 2009 16:32
#283788
Hey y'all,
I have a '79 KZ650SR - D2 w/dual front calipers
I switched out my bars and there's barely enough room to mount the stock master cylinder. Also, I'm going to change the stock lines to SS braided.
I have a couple of questions:
Is there a "short" master cylinder/reservoir for sale that will work with this setup? I know the mc bore is 5/8" but I'm not sure what specs are important when making a switch like this. I would guess the diameter of the bore and the length of the bore.
Could I switch to a master cylinder (with an integrated brake light switch) for single caliper system and then just remove a caliper and rotor? I like this idea cus then I could ditch that splitter and just have one cable from the mc to the right caliper.
I know most want KZ riders want to switch from a single caliper to a dual caliper but I'm thinking that a simpler system with newer components (especially the ss braided line) would lead to a better braking. Plus, most motorcycles only have 1 rotor up front anyways.
Looking forward to your responses
  • clutch2k3
Re: replace master cylinder
21 Apr 2009 19:44
#283905
  • riverroad
  • riverroad's Avatar
  • 1980 1000LTD B4
22 Apr 2009 07:55
#284027
Clutch, don't know about going from two discs to one, but to solve your master cylinder fitment problem, a lot of the newer bikes have remote reservoirs, and you could fab a small bracket to move it around wherever you need it.
Either that, or maybe an old MC from a single disc Z1 would fit better. Not sure though.
