Air pressure in forks
- Jay_G
05 Mar 2006 01:08
Im doing up a GT 750 (kz750-p1) and it has pressurized forks, i'm wondering what will happen if i do away with the pressurized system and leave the little ports open to the atmosphere, as i want an uncluttered looking front end and would like to get rid of the manifold that links the two fork tubes together.
any thoughts on the idea and how it will affect handling?
- steell
Re: Air pressure in forks
05 Mar 2006 08:47
Don't leave them open to atmosphere, plug them, then it should be fine (if you don't weigh over 200 lbs anyway).
I think a set of Progressive fork springs might work better with 0 air pressure though
- RetroRiceRocketRider
05 Mar 2006 09:14
I'm not to familiar with the GT750 in how the forks are set up since it was a non-US model.
But if it's anything like the GPz models offered in the US and had the equalizer tube (ref# 51044 in the pic below), then you can't remove that setup since the upper fork tubes have a corresponding hole in them that allows the air to "balance" between each side.
Removing it would leave the inner prings/oil/bushings/etc open to the elements and condensation.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Duck
- e vica na i sau na ga
05 Mar 2006 09:25
My Honda has a Schrader valve on top of each fork. Use a hand held
bicycle pump and a guage to set them up. No manifold. Very clean
looking.
-Duck
looking.
-Duck
- DanOz7Five0
05 Mar 2006 12:59
My 80 LTD forks each had their own Schroeder valve also. I busted up one valve so I just used the caps off a standard set of forks.
- Fossil
05 Mar 2006 13:31
This link might give you something to work with
gpzrider.lagemann.org/technical/FAQ2000....Chassis%20and%20Body
