GS1100 swingarm.. now what...???
  • Mercymac
  • Mercymac's Avatar Topic Author
15 Apr 2009 15:56
#282055
Alright, Ive got my GS1100 swingarm on the bike with the ninja rim and the pirelli diablo 180 in it, but no i have some questions. Where can I get a good pair of shocks to fit this kind of swingarm?? the bottow mount calls for a slotted shock mount versus the solid tube shock mount like the KZ swingarm calls for. The next thing is yes I know i need to off set my front sprocket.. but how much> can I get away with a 5/8 sprocket?? and what about the chain, what kind of chain do i need to go with??
"If you dont know where you're going, its hard to get there.."
  • otakar
  • otakar's Avatar
Re: GS1100 swingarm.. now what...???
15 Apr 2009 16:07
#282058
You require a set of shocks which fit a Honda :angry: "Lead Wing" You can get them from BikeBandit. com and they are made by Progressive Suspension. Part #12-1205B. They are 14" long and will make up for the mounts being farther back on the swing arm.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • T_Dub
  • T_Dub's Avatar
15 Apr 2009 16:48 - 15 Apr 2009 16:48
#282074
Just weld up that wrench and go rigid! :woohoo:
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Last edit: 15 Apr 2009 16:48 by T_Dub.
  • kzmarvo
  • kzmarvo's Avatar
15 Apr 2009 17:56
#282083
The shocks from the gs will work, and a 3/8 or 5/8 offset sprocket with bearing support(only on the 5/8) from what i have read on here.
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
  • toadson
  • toadson's Avatar
15 Apr 2009 22:38
#282152
I bought some new shocks on ebay for a GS1100 and they fit fine. My swingarm is very close to the frame when the shocks are full extended. My bikes sits just like your swing arm in the picture. Notice how close your swing arm is right now to where your exhaust bolts to on the frame.... mine has just enough room to fit a credit card in, but it never touches the frame.
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
16 Apr 2009 08:17
#282233
make sure the rear wheel is pushed all the way to the front of the slots and tie a string on the back of the rear sprocket and pull it forward up to the countersprocket and measure between it and the string and you can tell us what offset you need.it seems to vary from bike to bike.
hth,
leon holmes
  • Mercymac
16 Apr 2009 20:34
#282402
Otakar, I checked out those shocks and it looks like they have to tubular mounts, unlike the slotted one I need for the swing arm.. maybe im lookin at it wrong... idk
www.bikebandit.com/product/12511
