Triple Tree Clamp
- Darkangel
Triple Tree Clamp
15 Apr 2009 00:12
Will the top triple tree clamp off a 900, 1000, fit the 1100 KZ? Mines is a 82 1100
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- Mcdroid
- Gone Kwackers
Re: Triple Tree Clamp
15 Apr 2009 03:57
In a nutshell, no. Maybe.
Fork tube diameters on the KZ900 are 37mm, as are the later successor KZ1000. The next generation 1000's, the 'J' series, have 39mm diameter fork tubes, as does the KZ1100 series. So maybe a post-1980 triple tree might fit. The 1979/80 KZ1000 Shaft series has a different tube diameter than both the 900/1000 and the later 1000/1100 tubes and will not work either.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- StreetfighterKz
15 Apr 2009 04:11
Mcdroid wrote:
The Z1/Kz650/900/1000 and maybe some others are 36mm not 37mm. Also the early police bikes are 38mm.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Mcdroid
- Gone Kwackers
15 Apr 2009 04:34
StreetfighterKz wrote:
You are correct...to be even more precise, fork diam. on the 650/900/1000 series is 36.4mm and that of the 1000/1100 series is 38.4mm
Mcdroid wrote:Fork tube diameters on the KZ900 are 37mm, as are the later successor KZ1000.
Later, Doug
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Darkangel
15 Apr 2009 06:05
does any body have one....crap i am in need of one badly...
- trianglelaguna
15 Apr 2009 06:43
i think the later cop bikes share the same top tree...post a pic of the issue and the guys may come up with a trick you can home do to salvage yours....just for info....i bought an entire early model trip/tree/stem/lower tree/all bolts/bar clamps....the whole animal for like twenty on e-bay once cause no one bid....you may find one too...cause a lot of cop bikes get parted out on e-bay.....bet it can be fixed though with a aouto zone thread insert??????post a pick...good luck....shit happens....craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Darkangel
16 Apr 2009 20:34
Well guys...I know what I am going to do now...I will be dropping the front a little bit to get it ready for clip ons...
no club man bars crap....I have a few choices...I can go out and find some 38mm clip ons at the junk yard...or from a FZR 600...which i have....or I get them off ebay...OR some universal ones....What do you guys think.
- Darkangel
17 Apr 2009 07:50
anybody on the clip ons....
- StreetfighterKz
17 Apr 2009 08:07 - 17 Apr 2009 08:07
The problem with OEM clip-ons is that normally they don't clamp around the fork legs. They usually bolt to the triple tree.
I had a set of Paolo Tarrozzi clip-ons on my 1000 for a while. They're good quality but the problem was that the wat they assembled would let the bar move a little from it's original position.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 17 Apr 2009 08:07 by StreetfighterKz.
- Darkangel
17 Apr 2009 19:23
the one that I have looked at really do bolt on to the forks instead of the triple tree....,but right now I am faced with having to buy a knew triple tree clamp....and I cant find them on ebay as it is...
- FloridaBiker
18 Apr 2009 05:44 - 18 Apr 2009 05:46
On a 81 KZ1100 and a 83 KZ1000 the triple clamps will interchange and work well. (I have both bikes and have tried it)
The actual castings are different, because the mounting brackets (INSTRUMENTS, BOLT HOLES FOR BRACKETS, ETC) are different.
I have an extra KZ1100 triple clamp if it will help
Last edit: 18 Apr 2009 05:46 by FloridaBiker.
- Darkangel
20 Apr 2009 19:57
man how much do you want?
