750 twin swingarm swap?
  • flht1997
  • flht1997's Avatar Topic Author
10 Apr 2009 09:44
#280271
just playing in the garage now that spring is coming and the 750 twin is working its way to the front. the P.O. left it sit outside for over 10 years. it was in pretty decent shap and it took little work to get it running fine but the first ride verifid that something was not right. a quick inspection and i found the swing arm is rusted in place. after a few hours i was able to move it up and down about an inch. the pivot bolt is rusted to the inner sleeve and it does not really want to budge with normal removal techniques, i.e. BFH. i am pretty sure to get it out i will end up wrecking it. so the question is, i have a 85' GPZ750 swingarm with the shock mounts moved to the top that i had planned to put in my 650, but have given up that plan cause i do not wish to mess around with the drum to disc swap. since the 750 has a rear disc it should be easier. do the step remain the same? drill the pivot bolt hole to 17mm and intall just like before? anyone have insight or advice?
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
  • timebomb33
  • timebomb33's Avatar
Re: 750 twin swingarm swap?
10 Apr 2009 23:01
#280577
measure the swingarm across the pivots and do the same with the other swingarm see if it will fit there if it does it should be a peice of cake to do the swap.
I THINK MY POWERBAND BROKE
