Replacing rear master cylinder
  • drmadd95
  • drmadd95's Avatar Topic Author
09 Apr 2009 21:07
#280108
I have the same problem that KF4ZHT posted about in regards to rebuilding a 14mm rear master cylinder; no kits available. I also do not want to mix and match kits to make a working kit and currently the one I have is leaking fluid around the piston.
I have a 5/8 rear master cylinder that I am sure came off of a KZ1000. Z1 has kits available for this unit.
Before I buy the rebuild kit and replace the 14mm with the 5/8 master cylinder I wanted to get some opinions. Does anyone think that this would be too big of a master cylinder for my KZ650?
For reference the brake system I'm using came from a 78 KZ650 SR which has twin pistons in the rear caliper.
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Replacing rear master cylinder
09 Apr 2009 21:09
#280110
i think thats a single piston caliper B)
  • drmadd95
09 Apr 2009 21:18
#280112
I thought it was too, but I took it apart last fall to rebuild the piston and found one piston on each side of the brake disc. Of course my definition of twin piston could be wrong :lol:
