KZ650C Rear MC Rebuild
- KF4ZHT
09 Apr 2009 07:28
I have checked most of the vendors I can find and even emailed cyclebrakes. I am having no luck finding a rebuild kit or even a cap for my rear MC. Has anyone found a source for these parts?
- timebomb33
Re: KZ650C Rear MC Rebuild
09 Apr 2009 07:36
there is an outfit called k&l supply they handle all kinds brake rebuild kits
I THINK MY POWERBAND BROKE
- N0NB
- Blue handles better
09 Apr 2009 09:11
The Kawasaki parts diagrams show most items as "Cancelled" which isn't a good sign. Perhaps the folks at Z1 Enterprises can assist.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- SPARKY47
- 1980 KZ500 B2
09 Apr 2009 15:28 - 09 Apr 2009 15:42
delete pls
1980 KZ500 B2
Last edit: 09 Apr 2009 15:42 by SPARKY47. Reason: Im old
- hardr0ck68
- Who put the what in the where?
09 Apr 2009 20:10
I have talked to Jeff about this... this is one of the parts (at least for my 1977 650c1) that he could now get. There are just no kits. Now he did say that pieces from various kits could be put together to get you most of the way there but the big problem is the piston seal.
You would have to use the original piston (worn as it may be) then pry (or cut) off the old rubber seal, then carefully force the seal off another piston (ment for some model's front MC) then use it to replace the seal for yours.
Basically it seamed to me that I would need to purchase at least 2 kits, then mix and match parts and hope I could get that seal off of the new piston(the piston is for a completely different MC it just uses the same size rubber seal) and on to the old piston.
Too expensive and too much risk of failure for me... I just seriously cleaned the old unit and I will use it till a modern unit can be fitted.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- KF4ZHT
10 Apr 2009 06:20
hardr0ck68 wrote:
Thats what I kind of figured, thanks for letting me know so I didn't have to go through the whole process.
I think I can clean it up well enough, the bore is not pitted, just rusted. I would like to find a new cap and seal, but the PO may have it in a box of parts, he is trying to sort out what parts went with what bike.
I saw on here someone found a blue replacement cap for theirs, anyone know where to find one of those?
- SPARKY47
- 1980 KZ500 B2
11 Apr 2009 18:42
kf4zht.Is this what youre after?
cup primary 43019-001
cap oil cup 43026-004
plate master cylinder 43027-001
diaphram 43028-003
stopper piston 43022-002
dust cover 43024-003
piston assy 43020-1004
all available.
I've got a link not a couple of months old has all the bits.
But its buuried in my hellhole of a filing system.
Just say if you want to ruin my day.:woohoo:
diaphram 43028-003
all available.
1980 KZ500 B2
