Kz900 -kz1000 Dual disc swap.
- Geeto67
08 Apr 2009 16:10
hey all,
I did a search but I did not find any definitive answer so I am wondering if y'all can help me out.
I have a 1976 kz900 with spoked wheels. A friend parted out his kz1000 LTD (not sure of year) and all he has left is the front end with mag lester style rim which he offered to me. What I want to know is:
Can I use the LTD's dual disc brake setup on my stock spoke kz900 wheel and forks?
or
Will the LTD front end slide into the triple clamps of my kz900?
What should I look at when evaluating the LTD front end? Really I am just after it because my kz900's single caliper is nasty and his brakes are freshly rebuilt. I want to keep my spoke rim because I just mounted a new tire to it and really don't feel like taking it off again.
or
- kaw74z1
- 0 to 60 in 15 minutes.
Re: Kz900 -kz1000 Dual disc swap.
08 Apr 2009 16:44
I put a set of forks from a 1978 kz 1000 on my 1974 z1 and they slid rite in the trees. I had no problems at all.
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
- Stormin Norman
23 Apr 2009 13:12
dude; i am in the same boat. have a KZ900A4 and love my spoke wheel but want more stopping power. so i am looking for a 76-80 LTD and they came with duals up front.so its of to the bone yards in my town-metropolis-denver. i am told this is the way to go.will keep you posted and if you have any info would appreciate it...
- timebomb33
23 Apr 2009 20:18
it should be just about a straight bolt in but in case it's not i could really use a front lester mag for my own hotrod it should fit easy as long as you use a master cylinder for a dual disc setup.
I THINK MY POWERBAND BROKE
- oldkaws4ever
- Have no regrets...... You only live once.
23 Apr 2009 21:02 - 23 Apr 2009 21:06
Im 99.9 pecent sure it will be fine. I just did the same thing on my 74 z1, i put tripple disk mags from a 79 ltd 1000 be. The front wheel bolted up to my z1 forks fine, and i swapped swingarms for the ltd 1000 one. Complete bolt on application. Here are some pics.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 23 Apr 2009 21:06 by oldkaws4ever.
