Brown Tires
- HerrDeacon
Brown Tires
07 Apr 2009 18:06
Wondering if there is anything to help tires look black again? My tires, even though they are fairly new, always look dirty brown. Its now even worse since I just painted my rim, shows it up more now. I've washed them but still look like crap. My tires are a cheaper brand so I'm not sure if this is a factor.
I know you can't use car type gels and stuff, but is there any safe way to bring back the black?
- MFolks
Re: Brown Tires
07 Apr 2009 22:00
After scrubbing the tires with a good cleaner, dry,and apply some paste wax(I use Johnson's in the yellow can),work it into the tires and buff off the excess. It should keep them looking black foa a while.
- Russ Jackson
Re: Brown Tires
08 Apr 2009 05:23 - 08 Apr 2009 05:27
Try this product it has been around for a million years.
Westley's Bleche-Wite
www.westleys.com/
Available just about everywhere...Russ
www.westleys.com/
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Last edit: 08 Apr 2009 05:27 by Russ Jackson.
- Bluemeanie
Re: Brown Tires
08 Apr 2009 05:42
I've always used Armoral or Formula 2000, add to rag and wipe on being careful NOT to go past "shoulder" onto tread. Let set and then buff off excess.
- HerrDeacon
Re: Brown Tires
08 Apr 2009 06:07
Thanks guys for the tips, I'll try them out.
Russ, I've never seen that Westley's product around here before. I'll have to check around a bit more.
- T_Dub
Re: Brown Tires
08 Apr 2009 06:41
Don't drive around in the mud Deacon
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- HerrDeacon
Re: Brown Tires
08 Apr 2009 07:11
T_Dub wrote:
Hard not to around here. If you saw the mud and dirt I cleaned out of the front of the engine this winter it'd scare you. I should be a few pounds lighter now :laugh:
- racer54
Re: Brown Tires
08 Apr 2009 10:13
Follow Bluemeanie's advice...DO NOT get anything you use on the tread area of the tire. You will be in for a very interesting ride at the least and quite probably dangerous and bad for you health , if you do. Be very careful. This stuff is slick and the tread is no area for this stuff. I have, as well as a few others here I'm sure, have found out the hard way how this works. DO NOT get on tread of tire! Hell...don't even use it on your seat...same thing, different situation. I have just about came off seat on easy take-off it was so slick so you can imagine what it would be like to have this stuff between your tire and the road.
- loudhvx
Re: Brown Tires
08 Apr 2009 10:49
racer54 wrote:
When I was kid working at a bicyccle shop, if the customer was an A**hole, my buddy or I would Armor-all the seat for him. We'd always make a point to tell him as if we were doing him a favor. The seat looked so nice, they'd always thank us.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
