GPZ 550 fork caps
  • GPZPDX
  • GPZPDX's Avatar Topic Author
GPZ 550 fork caps
31 Mar 2009 19:03
#277194
I pulled apart my forks to replace the seals and, now that I'm down to the last reassembly, I can't get the fork caps to compress.
The springs are in correctly, the forks are fully extended, the spacer washer is in place. I can easily push the spring 4-5 inches down inside the tube.
But, the fork caps only go in to where the tops of the caps are about 2-3 mm inside the fork and then they seem to bottom.I've got 10mm or so to go before the groove for the spring clip becomes visible.
What is it hanging up on? I've turned it, hammered it, pressed it and no go.
1981 GPZ 550
1978 GS 1000 (x3)
1970 450 Mk IIID
  • gane
  • gane's Avatar
Re: GPZ 550 fork caps
31 Mar 2009 19:46
#277222
G. this may be worthless, but a vet's approch to installing /removing circlip located fork caps is simply squeezing fork tube. at a guess, you're using bike to hold tubes. if so, simply loosen upper clamp bolts. if I'm right releasing tension will allow cap to travel. metering tension will allow penetrtion and hold to allow fitting retaining ring. luck G
[img][/img] 1977 KZ1000A1
  • GPZPDX
01 Apr 2009 11:48
#277418
Well,tube compression is not an issue
I've got the tube set in my vise about 1 foot down from the top.
I've looked at it some more and it looks like the cap won't fit into the bore that's below the clip groove.
I pulled the O ring to confirm that it is not the problem
Any other ideas?
1981 GPZ 550
1978 GS 1000 (x3)
1970 450 Mk IIID
  • timebomb33
  • timebomb33's Avatar
01 Apr 2009 11:55
#277422
if it came out of those forks it will go back in i always put the tubes back in the trees and only tighten the bottom bolts you might some help for this next part, i use a 1/2" bereaker bar and push down as hard as i can they will go you will get more leverage if the tube is in the trees on the bike . when you get the cap pushed it to place get your helper to put in the circlip. and make sure it is seated or it will blow out in to your face at the wrong time. make sure the forks are extended all the way out before you attempt this.
I THINK MY POWERBAND BROKE
  • GPZPDX
01 Apr 2009 11:59
#277423
No offense, but if it would go right back in, I wouldn't be posting as to why it won't.
Force is not the issue.
1981 GPZ 550
1978 GS 1000 (x3)
1970 450 Mk IIID
  • loudhvx
  • loudhvx's Avatar
01 Apr 2009 12:02
#277424
I've done this countless times on that bike and it should be easy. Forgive me if this sounds dumb, but are you sure the clip is not already in the groove?
Is it the same problem on both forks, or did you only do one?
  • loudhvx
  • loudhvx's Avatar
01 Apr 2009 12:05
#277428
There's no chance the cap is upside down is there? Probably not unless you took apart the air valve and put it on the wrong end. Sory, I know these suggestions are unlikely, but have to cover everything.
  • GPZPDX
01 Apr 2009 12:30
#277438
Thanks,
But no
and no
Both forks have the problem - I've tried switching the caps on the tubes - no luck
It does seem awfully basic, that's why I'm stumped!
1981 GPZ 550
1978 GS 1000 (x3)
1970 450 Mk IIID
  • T_Dub
  • T_Dub's Avatar
01 Apr 2009 12:36
#277439
Have you tried pulling the springs back out and trying to fit them in?
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • GPZPDX
01 Apr 2009 17:05
#277492
Yep,they still just sit there
I posted in hopes this was a more common problem, even tho I've never had it happen in 40 years of wrenching on my bikes.
I guess I'll break out the Dremel and put a little chamfer around the base of the cap to see if it will slip into place
1981 GPZ 550
1978 GS 1000 (x3)
1970 450 Mk IIID
  • loudhvx
  • loudhvx's Avatar
02 Apr 2009 02:12
#277627
Damn that is wierd. I hate to see ya dremel it and then realize what the problem is.
  • GPZPDX
02 Apr 2009 12:29
#277718
Me too.
That's why I'm taking my time.
What with hail and 46 degrees out, I'm in no hurry. I need the garage space to work on my GS, tho.
1981 GPZ 550
1978 GS 1000 (x3)
1970 450 Mk IIID
