KZ1300 rear wheel
- Z1Rider
KZ1300 rear wheel
29 Mar 2009 15:10
Has anyone tried to put a stock KZ1300 rear wheel on a GS1100 swing arm? It's going on a 78 Z1R. The KZ 1300 wheel is wider than the stock Z1R rear wheel I have now, and matches the front in style. I know it's a 17", I can live with that, the goal is to mount a wider rear tire.
- flht1997
Re: KZ1300 rear wheel
29 Mar 2009 15:31
IIRC the 1300 was a shaft drive, it would be quite a bit of work to adapt a sprocket much less getting it in a GS arm, but i could be wrong
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- KZQ
- Administrator
29 Mar 2009 15:34
I suppose that will depend on whether or not the drive paddles from the chain drive will fit into the cushions in the shaft drive 1300 wheel. My memory says they are two different creatures.
I've got an extra wheel but I don't have and extra chain drive hub if that's what it's called.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- otakar
29 Mar 2009 18:29 - 29 Mar 2009 18:38
The answer is NO. I have both and they will not interchange. the hub is too different, and will not take a sprocket hub. Go with a LTD 16" wheel it is also wider and will drop right in. Here is mine in a GS swing arm in a GPz1100. And "Progressive suspensions" Honda Lead Wing shocks, #12-1205B. They are 14" long and will offset the longer swing arm which has the mounting points farther back. This makes the bike sit right and retain your good handling. If you use stock length 12" shocks the rear end will drop too much and she will handle like a Pig.
PS. I also forgot to mention You will pay a pretty peny for a "17 tire, that size is usually only used on large touring bikes. The 16" however is very common and are very cheap.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 29 Mar 2009 18:38 by otakar.
- otakar
29 Mar 2009 18:40
I also did forget to mention. One thing you WILL require from the 1300, is the axle. It is the perfect length for that swing arm width. That is what I am using.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Z1Rider
30 Mar 2009 04:56
What size tire did you put on your LTD Wheel? Thanks
30 Mar 2009 09:31
how about some pics of that z1r?there are a few of us on here but most don't come out much.i built my own swingarm and put a 17" r1 wheel with a 200 mm rear tire.
here is a fuzzy pic,there are clearer ones in "my 1980 z1r and 900 projects" in the projects.
leon holmes
leon holmes
- otakar
30 Mar 2009 15:17
Z1Rider wrote:
It's an MT90-16 which should be about a or 150. or just over 5.75 inches wide with a 90% profile height. This gives really good handelling performance.What size tire did you put on your LTD Wheel? Thanks
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Z1Rider
31 Mar 2009 17:40
OK Banshee I'll give it a shot, I have had trouble posting pics in the past here so here goes... Took these today.
- Z1Rider
31 Mar 2009 18:34
TO ALL... I apologize in advance if this dosen't work. I am now trying photobucket. I might need a few more trys to figure this out, either using photo bucket or resizing. This is a new computer w/Vista and I'm still figuring out the vista deal. Just ignore me.:S
01 Apr 2009 08:25
hey thanks for the pics.that looks like one of those sought after x-pipes ya got there,do you know the brand of it?
your z1r looks pretty complete,who built the handle bars?
triangle when i got my 1978 z1r my dad had already put a 19" front and a 16" rear on the bike to get the axles at different heights to help combat the high speed wobble.it must have worked because i never had any speed wobble problems.burnt up 7 topends because of low gearing tho,i was a slow study.
glad it will be kept in the family,keep us posted now that you got the picture/vista thing figured out.
leon holmes
leon holmes
01 Apr 2009 08:31
are those 34mm keihin cr's you got there for carbs?
leon holmes
leon holmes
