Frame crack.
- TeK9iNe
- What did you do!?!
Frame crack.
27 Mar 2009 22:23
OK, so here's the skinny...
I've got my frame all stripped down and looking ready for some powder.
When low and behold, on the underside of the frame at the very back of the main lower frame pipe (just in front of the center stand cross-pipe weld), is a crack that goes half way around the pipe!
I'm pretty sure its some kind of stress fracture from P.O. :dry:
I tried to use a spreader to open the crack slightly, but the frame is TIGHT, and it would'nt open.
So... I just smashed some JB on/in it... Will this be enough?? :huh:
I'm no wheeleing this thing...
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Becker
- The Doctor Will Rise Again
Re: Frame crack.
27 Mar 2009 22:47
I'm not a frame builder but that definitely wouldn't be enough for me. I would bevel the surfaces of the crack and weld it shut. Then possibly gusset it if possible since it seems to be a stress point. JB weld can work good for some things but it doesn't fuse the metal so the crack could keep spreading. I just wouldn't be able to ride that bike comfortably knowing that.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- timebomb33
Re: Frame crack.
27 Mar 2009 23:07
you have the frame stripped down all ready get it welded it's a 1000 cc bike not a honda spree scooter do it right like becker said and you will be able to sleep at night knowing it was the right thing to do.withthe motor out it will be so much easier and then get it powder coated.
I THINK MY POWERBAND BROKE
- jswag5
- whats the big deal about harley, i prefer 4 cyls!!
Re: Frame crack.
27 Mar 2009 23:22
never trust a cracked frame, ive seen people topple when a weak frame crumbled underneath them.
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
- KawiConvert
Re: Frame crack.
28 Mar 2009 00:05
Definitely get it welded and possibly braced or have a section welded across the cracked spot to help distribute the load. It may not spread right now, but under load if it starts moving everything else will start flexing and wear out fast.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- TeK9iNe
Re: Frame crack.
28 Mar 2009 06:39
Thanks for the replies :lol:
The bike was deffinately in an accident before I got it, so I had an old neighbor of mine look at it before I rode last year. He said the welds were fantastic, whoever did it. Theres even chunks of extra bracing everywhere. Guess we just missed that crack with all the old paint... :ohmy:
:dry:
So really, you guys dont trust the JB weld that much?
It reportedly has a higher tensile strength than steel...
Not that I care wether or not I use it or get it welded. Like said, its just a bare frame right now, its the best time while I can toss it around with a couple fingers.
Cheers.
How do you check/know if a frame is a "weak one"???never trust a cracked frame, ive seen people topple when a weak frame crumbled underneath them.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- trianglelaguna
Re: Frame crack.
28 Mar 2009 07:09
if i found crack in my frame ...i might be tempted...but in the in i would flush it....
crack kills and yours just might
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- PLUMMEN
Re: Frame crack.
28 Mar 2009 09:59
drill a small hole in each end of crack before welding it up.
- donthekawguy
Re: Frame crack.
28 Mar 2009 10:19
JB weld will not work. Like stated before it does not bond the metal. You could use duct tape for the same effect as JB Weld on cracked metal.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Becker
Re: Frame crack.
28 Mar 2009 10:31
JB weld might have a higher tensile strength then steel or maybe not I don't know, but it won't adhere to the metal stronger then if you welded it and it was fused with a weld.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- mtkawboy
Re: Frame crack.
28 Mar 2009 10:50
I have a crack in the gusset on the frame by the steering neck on my Z1. Its only about an inch long but it worries me. Right now theres a brace tying the 2 front frame rails together
- PLUMMEN
Re: Frame crack.
28 Mar 2009 10:55
thats a common issue on z1s and early kzs .if frame is straight it can be welded up easily enough and gusseted from back side if your worried about it happening again
