Kickstand issues...
  • schmol
  • schmol's Avatar Topic Author
Kickstand issues...
27 Mar 2009 17:12
#275890
hello everyone, I'm cafe'n my 1982 GPZ750 and I am having a issue with the kickstand. I guess this question is for others that have a similar project...anyway, i used a set of rearsets off a '03 GSxR600 and mounted them using custom brackets off the passenger peg mounts and at this position, the kick stand is soo much in the way.
has anyone attempted to move the kickstand or bend it out of the way?
  • KawiConvert
  • KawiConvert's Avatar
Re: Kickstand issues...
17 Apr 2009 18:15
#282685
Nope, mine fit the rear sets, but just barely. You could make a new one, just keep your bike at the same lean angle.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
18 Apr 2009 07:25
#282795
When I install '04 GSXR600 rear sets only the side stand spring needed to be flipped around.
The attachment that fits over the spline shaft does not go on all the way because it will hit the frame, but I've had no problems with it coming loose or off in 2 years.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • KawiConvert
18 Apr 2009 20:04
#282959
If I remember right, mine is off of a Honda nighthawk or some other <750cc Honda. It is cast with a bend in it that clears the frame, and barely clears the spring. If I move my splined portion one more spline then it will hit the spring or stand.
