Concours rear wheel on 1980 Kz1000
  • dejavoodo41
  • dejavoodo41's Avatar Topic Author
26 Mar 2009 11:04
#275526
I recently purchased a 1980 Kz1000 and the previous owner has adapted a concours rear wheel to chain drive. I need to replace the bearing on the drive hub but have no idea what it is off of. It is running a 630 chain with a 38 tooth sprocket. If anyone has a clue as to what this setup may be the info would be greatly appreciated.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Concours rear wheel on 1980 Kz1000
26 Mar 2009 12:01
#275546
You may have stumped us...a picture might aid greatly, but you might have to knock the bearing out to see what it is:(
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • timebomb33
  • timebomb33's Avatar
26 Mar 2009 12:25
#275550
the bearing type and number will be on the seal in the bearing look for a 4 digit number like 6205 something like that. the seal will have the measurements on it as well
I THINK MY POWERBAND BROKE
  • dejavoodo41
26 Mar 2009 17:28
#275624
Thanks for the replies. I ended up just taking it to the dealer. They had no clue either but were able to match the bearing and get it repaired.
