Changing out handlebars
  • civilengr3
  • civilengr3's Avatar Topic Author
24 Mar 2009 04:55
#274773
Are there step-by-step instructions anywhere on changing out the handlebars? Never done this b4 and not sure what is involved and what I'll need.:unsure: My '77 650C currently has custom Z-bars, which I abhor.
1977 KZ650C
East TN
  • timebomb33
  • timebomb33's Avatar
Re: Changing out handlebars
24 Mar 2009 05:12
#274778
unles they are apehanger z bars every thing should be a straight swap over.
I THINK MY POWERBAND BROKE
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
24 Mar 2009 05:34
#274782
A lot will be determined by how much it was hacked up in order to install the Z-bars. On the 77 650C when it came from Kawasaki the wiring for the switches was run on the inside of the bars. They only did this in 77 and 78 and it was a real PITA. I'm guessing that whomever put those bars on did not run the wires on the inside of the bars, most likely they hacked a notch in the bottom of the switches. Pictures would help in formulating a plan of attack.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • Locozuna
  • Locozuna's Avatar
24 Mar 2009 05:47
#274787
Wires should be color coded so it should be just unplug and re-plug. Swapping the bars should just be unscrewing the control pods and the 4 main clamp bolts (make sure you lay a towel on your tank so you don't chip it with the bars). Are your wires run inside the bars or on the outside? Pics would certainly help.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • civilengr3
24 Mar 2009 08:37
#274836
wires are all on outside, so that shouldn't be a problem. I'll try to take some pics tonight. I was wondering mostly about the grips and throttle and how they come off/attach to new bars. It wasn't really obvious to me how all that comes apart.
This is a relatively short z-bar, not ape hangers, so I think the length of wires, etc. should be ok.
1977 KZ650C
East TN
  • civilengr3
24 Mar 2009 17:03 - 24 Mar 2009 17:11
#275009
1977 KZ650C
East TN
Last edit: 24 Mar 2009 17:11 by civilengr3. Reason: nothing there b4
  • MFolks
  • MFolks's Avatar
24 Mar 2009 17:15
#275016
On the stock bars a small hole is drilled to index the switch pods so they do not rotate. Carefully measure the pin in the switch assembly and drill a matching hole in the new bars. I think the hole size is 1/8" but check anyway.
  • RonKZ650
  • RonKZ650's Avatar
24 Mar 2009 17:33
#275030
Trust me, whoever installed those bars didn't drill anything, they cut off the pins. Everything comes apart real easily. A couple philips screws from the bottom on each switchgear and you just separate them in half and the come right off.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
24 Mar 2009 19:05
#275063
When changing 'bars, your cable and hose lengths may need to change. It is important to make sure cables / hoses can clear headlights and headlight brackets without major contorsions. Master cylinders can be problematic if you run very low bars (like drag bars) - the hose output from the master cylinder can bang on the side of the tach. What you don't want to do is let the end of your throttle assemble hand too far off the handlebars.
If you change the riding position significantly, the weight distribution on the tires will change. This can affect handling. Sometimes slight tire pressure changes are needed.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • Locozuna
  • Locozuna's Avatar
24 Mar 2009 19:17 - 24 Mar 2009 19:17
#275071
Holy twisted buckhorn nightmare handlebars BATMAN!!!! Never seen the like! I got some twisted railroad spike highway pegs on the 900 I'm not really fond of but twisted apehangers!!! MY EYES!!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Last edit: 24 Mar 2009 19:17 by Locozuna.
  • civilengr3
25 Mar 2009 06:53
#275199
yup, they're horrible. And they're close together, so it feels like I'm steering my daughters tricycle. I actually had a couple of people tell me they like them :blink:
1977 KZ650C
East TN
  • timebomb33
25 Mar 2009 07:05 - 25 Mar 2009 07:06
#275204
it's cause there ol skool dood.:silly: :silly: :woohoo:
Last edit: 25 Mar 2009 07:06 by timebomb33.
