76 KZ900 shock studs on the frame, need help!
  • TexasKZ900
  • TexasKZ900's Avatar Topic Author
22 Mar 2009 15:45
#274309
I have a 76 KZ900, does any body know how the shock studs are fixed to the frame, welded, pressed in, or screwed in?
I'm putting a ZRX1200 swingarm on the bike and need to modify them.
Thanks
  • MFolks
  • MFolks's Avatar
Re: 76 KZ900 shock studs on the frame, need help!
22 Mar 2009 15:50
#274312
On most of the bikes, the studs are welded into the frame.
A thread on this was recently listed at:http://www.kawasakimotorcycle.org/forum/mechanics-corner/100914-broken-shock-stud.html
  • TexasKZ900
22 Mar 2009 16:02
#274317
Thanks for the quick response, I'll checkout the link.
  • donthekawguy
  • donthekawguy's Avatar
25 Mar 2009 02:12
#275161
This is one of the great mysteries that no one has the answer for. There is no weld that can be seen and it looks to be pressed in. I have a bad one on my 78. am going to find out one way or another how those things are put on the bike this summer. I will let everyone know how they are attached to the frame. I think I'll try heating it up first and press it out. If that doesn't work I'll grind a couple of flat spots on it and see if it screws in. If that doesn't work I don't know what I'll try but it will come out one way or another.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • timebomb33
  • timebomb33's Avatar
25 Mar 2009 17:26
#275363
just cut it off flush and drill it out to the size you need to go to.
I THINK MY POWERBAND BROKE
