Modern Radial Tires
- ZTORCH
Modern Radial Tires
21 Mar 2009 00:43
Hi I am putting Metzeler Z6 radials on my kz900 170/60/17 on the rear and 110/80/18 front, has anybody tried this combo or anything close to it? So called experts say not to run radials on these older bikes,but I think this is bogus I am ordering these tires monday.Any input would help, this could be a costly experiment! Thanks ZTorch
- smithgpz
Re: Modern Radial Tires
21 Mar 2009 01:12
as long as you have the right width wheels and a swing arm wide enough for the tire you will be fine.new radial tires on a old bike work great.heres a pic of my kz1000 with a 180 rear.
- PLUMMEN
21 Mar 2009 08:52
depending on which bike youre working on id say the biggest issue is going to be swingarm flex and frame bracing,im guessing youve already dealt with the swingarm issue.
