needle bearings or bushings please help..
  • eddieteeth
  • eddieteeth's Avatar Topic Author
  • GIVE ME YOUR KNOWLEDGE
19 Mar 2009 21:07
#273617
im having a problem figuring out what i need for my bike. my bike is a 1978 c2 kz650 that had needle bearings in the swing arm. though when i ordered new ones from z1 i only found bushings listed for my make and model. so i went ahead and got them. will this still work?
IM BUILDING AN 810 BIG BORE FROM A 650 AND I NEED SOME ANSWERS.
  • timebomb33
  • timebomb33's Avatar
Re: needle bearings or bushings please help..
19 Mar 2009 21:09
#273618
yes that is what they came with originally
I THINK MY POWERBAND BROKE
  • eddieteeth
19 Mar 2009 21:13
#273620
so even though i took the needle bearings out the bushings will work also the book. show a different tube for the bushings. will the straight tube work. much appreciated...
  • timebomb33
19 Mar 2009 22:33
#273630
usally the swing arm pivot rides directly on the bushings as they are quite a bit thicker than the bearings i think but i'm not sure but the bushing kit comes with a spacer for in between the bushings.
  • RonKZ650
  • RonKZ650's Avatar
20 Mar 2009 06:59
#273671
No, you're wrong there. The 77s came with bushings, the 78s with 4 needle bearings. They are not interchangable. Different swingarm tube, different swingarm even on a 78 model. Bearing-needle, HK221 KZ650-C2~ 92046-1115
