Wheels on a KZ650C
  • Shoe48
  • Shoe48's Avatar Topic Author
  • Live each day as it is your last
Wheels on a KZ650C
01 Mar 2006 15:50
#27360
I found a GS1100E swing arm finally If I wanted to install a wider rim what would it be off of ? Also If I wanted spoke wheels and keep my double brakes on the front would KZ1000 wheels fit/ Are the rim widths are the same as stock KZ650c mags ,, ?? :whistle:
  • wireman
  • wireman's Avatar
Re: Wheels on a KZ650C
01 Mar 2006 16:01
#27364
650 and 76 - 78 900/1000 use the same front hub for wire wheels,you can use 1000 rear hub and just make spacers to match new swingarm. :whistle: goodluck,happy wrenching!
  • Shoe48
01 Mar 2006 16:45
#27373
Are the twins the same too ?
  • wireman
  • wireman's Avatar
01 Mar 2006 17:02
#27374
did they have 4 bolt rotors ?;)
  • Tower_Monkey1
  • Tower_Monkey1's Avatar
01 Mar 2006 19:49
#27436
Shoe, I think your gonna have to go to a newer bike for a larger rim size. The 900/1000 use the same size rims as the 650 I believe. The front is 19 and rear is 18 arent they wireman ? I did get a 130/90/18 to fit onto my rim off a 78 KZ650C2 . The C2 has the mag wheels front and rear. My rear disc had the four bolt disc and the front has the six bolt disc's . Wayne
Post edited by: Tower_Monkey1, at: 2006/03/01 22:51
78 KZ650C2 Dyna ignition and coils,Pod filters,4-1 Kerker,CBR Tail Light,Drilled front dics,Custom front fender,1/4 fairing.
  • Shoe48
01 Mar 2006 21:03
#27457
Thanks for the info ,, you are right about the disc brakes Tower - monkey , 130 is not bad , Chrome spokes do look nice though :) But will see what turns up ,,
  • wireman
  • wireman's Avatar
02 Mar 2006 00:28
#27474
yep stock wire wheels are 19" front,18"rear a 650 wire front wheel should also be 19"if it has 4 bolt rotor you should be set,Z1 had 6 bolt front rotor.;) goodluck,happy wrenching!
  • steell
  • steell's Avatar
02 Mar 2006 05:02
#27491
Yes the 750 twin shares the front wheel with the 650 and 1000 :)
