Shortest Rear Shocks possible??
  • mox369
  • mox369's Avatar Topic Author
16 Mar 2009 21:49
#272627
83 KZ 1100 shaft drive. I want to lower the back end as far as possible, i dont mind if i have to get the stiffest shocks out there so i dont bottom out. I figure this is easier than welding on a hard tail. Please give suggestions of how low i can go and what shocks you would recommend. (I tried searching for this topic already but couldnt find anything good)
83 KZ 1100 Shaft Drive
  • timebomb33
  • timebomb33's Avatar
Re: Shortest Rear Shocks possible??
16 Mar 2009 21:59
#272630
sportster shocks are about 11.5" long and there is an outfit from colorado that is making up 10.5" but they are really pricy and they are just cut down stock harley shocks if you go down to your freindly neighborhood hd dealer they might even have some takeoffs that they would be willing to part with reasonable.
I THINK MY POWERBAND BROKE
  • School Teacher
  • School Teacher's Avatar
16 Mar 2009 23:25
#272645
the knight rider put on some honda rebel shocks, and they worked, though he took his inner fender out. and it was on a 76kz900
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
  • mox369
17 Mar 2009 06:20
#272687
i am taking out the inner fender anyway so that would work great, i will PM him and find out what he used. Just so i know, what is the stock length? I prematurley threw away the old rusted out shocks on my bike.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
17 Mar 2009 08:52
#272724
It's not the inner fender you need to watch for - but the frame over the top of the wheel.
If you go with very short shocks your ground clearance will disappear.
If you run a 4-1 pipe, you will kill the collector on bumps.
If you run a center stand, the stand will ground dangerously on corners.
  • timebomb33
17 Mar 2009 08:58
#272728
also if you use shocks from a rebel that bike is about half the weight of yours and the rebel is designed as a small bike for smaller people to learn on so it wont have compatable spring or dampening rates for that size of bike that you are putting them on so they will bottom out easy and not give a really good ride.
  • mox369
17 Mar 2009 09:18 - 17 Mar 2009 09:20
#272736
Well As of now i dont have a 4 into 1 pipe but would like to, no center stand so i think ill be ok there, i am cutting off a the frame behind the shocks, but dont know if the part that is left will still rub, and since its a KZ 1100 do you think those shocks can handle that weight?? I only weight like 170. All thoughts would be appreciated, u guys have been a great help so far
P.S. i am new to motorcycles in general, will all shocks have the same mounting and eyelet size for my bike?
Last edit: 17 Mar 2009 09:20 by mox369.
  • School Teacher
17 Mar 2009 11:23
#272756
I know he just bolted them right on. They were actually pretty stiff because the geometry is different on a rebel so they worked. He ran a side winder exhaust. now he has a extended swingarm so he has longer shocks but they are mounted different.
thats all i know about it now,i will tell him to check his messages.
1980 kz1000G1
  • mox369
17 Mar 2009 15:45
#272810
Hey i just found these, let me know what you think, you have to scroll down to the 11.5" model and they are only $80.
www.mikesxs.net/products-18.html#products
  • timebomb33
17 Mar 2009 16:41
#272825
i have put those on for people before and they dont last very long the bushings aren't steel they are a plastic sleeve with a very soft rubber outer so they pound out very fast you get what you pay for like i said try the local harley dealer out and ask if the have any take-offs the bikes are comparable weights and they have the same style of mounting. and if they have takeoffs they might be willing to wheel and deal a bit especially now days with the economy as bad as it is.
  • mox369
17 Mar 2009 17:04
#272830
I appreciate the input and will shy away from those then, when i get a chance ill def. check out the harley dealer, when i go in i should just ask for 11.5" take offs? Thanks for the great idea Timebomb
  • timebomb33
17 Mar 2009 17:20
#272837
yes i'd just ask if they have any stock sporty takeoff shocks if you ask for them that way they probably wont be tempted to try sell you brand new ones.
