KZ750/4 LTD forks vs. KZ1000 forks
- tachrev
- Rubber Side Goes Down
16 Mar 2009 17:42
Will 1982 KZ750 LTD forks slide in place of my 1977 KZ1000 forks?
I know the tube diameter is the same, but is the tube spacing the same?
I want to put the entire front assembly(wheel/tires/brakes) from the 750 on my 1000 using my triple clamps, and put the 1000 setup on the 750 the same way.
Build Thread
Build Thread
- tachrev
Re: KZ750/4 LTD forks vs. KZ1000 forks
19 Mar 2009 08:20
Well, I couldn't decide if I wanted to pull my bike back apart to do the swap, and the other guy found another parts doner.
Worked for the best.
However, I decided to update the thread with the little info I found on my own, for future searches.
I am always finding thread that look like they might help with no resolution!
82 LTD750/4 15mm front axle, 20mm rear, 36mm fork tubes
Fork brace for this model has a 190mm center to center.
1977 KZ1000 A1 17mm front axle, 20mm rear, 36mm fork tubes
Fork brace for this model has a 185mm center to center.
That's all I found, may help someone later.
Build Thread
Build Thread
