New forks, different axle
- Mercymac
12 Mar 2009 07:31
I just purchased a shorter pair of forks for my KZ900A, and the axle diameter that it calls for is consistent with that of a Ninja 250, which i have the axle. Do i need to order a ninja 250 wheel? or can I replace a couple bearings and such in my KZ wheel to make it work with the smaller axle?
"If you dont know where you're going, its hard to get there.."
- StreetfighterKz
Re: New forks, different axle
12 Mar 2009 08:45
A wheel bearing swap is the easiest answer but remember that the new brake caliper(s) and old rotor(s) may not line up. What are the new forks from? Maybe we can help you figure out how to mix/match components?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Mercymac
12 Mar 2009 09:28
I bought the forks with the understanding that they were just shorter and needed a different axle.. when I recieved them I asked the seller what they were from, he said that they were from a KZ drag bike, that he had a ninja 250 wheel, tire, claliper, and rotor. So i started with just ordering a axle to see what i could do with my old wheel. So im going to swap the bearings today, and then I ordered a used caliper for a ninja 250 to apply to the new forks, and then i will see how the rotor lines up with that, If you have any Ideas i would GREATLY appriciate it!!
Thanks..
Thanks..
